4 Attachment(s)
Mystery Find what is it.??
Ordered load of Electrical parts from China and this was among them. WHAT is IT.? . . . . I've got an idea what it might be but lets see if you lot can figure what could be used for.?
Attachment 18774Attachment 18775Attachment 18776Attachment 18777
Re: Mystery Find what is it.??
Pic one looks like your lipstick that I have seen you with:playful:
Clive S
Don't be daft Clive, it's not Deans colour :tan:
As it arrived with electrical goods I'm assuming it is electrical related?
Is the pocket end for tinning large cable by creating molten solder container for dipping them in?
Is the pointed end for splaying multicore cable out?
So some kind of wire prep tool?
Is the pointed end spring loaded or fixed or is it removeable? Does it look like it would fit into the pocket end
? Otherwise give us a clue . . .
cropwell
That's what I was going to say.!. . . . I use same colour as you Rob. .:stupid:
routercnc
No there is hole thru the pointed end to the pocket so would run out.
routercnc
. . . . Too big would have to be large cable.
routercnc
Don't think so
routercnc
The red body is one piece aluminium the silver is plastic moulded to it which hold the black end caps.
When together it looks decorative like Lipstick.!!
Some sort of oiler or grease. I give up its too warm here:emmersed:
komatias
Crack pipe?
. . .. Close to what I'm thinking!!
Dean,
Do you actually know what it is ?
Rob
cropwell
Dean,
Rob
No not really I've got an idea which I think correct but want to see if anyone else comes up with it.!! . . . I could be miles off.??
You'll be needing some smoker's gauze or foil with lots of pin holes in it by the looks of that ;-)
- Nick
magicniner
- Nick
Where thinking along similair lines.! . . . I'm thinking Herbal or Snuff like snotter clearer. .:cower:
Is the knob end spring loaded ? Seriously !
Rob
I'm thinking Herbal
I've not done anything herbal for over 20 years ;-)
Unless you count aperitif :D
cropwell
Rob
No Springs attached Rob seriously.!!
magicniner
I count Guiness as Herbal medicin. . :beer:
cropwell
Rob
I wish mine was:apologetic:
Clive S
Told ya to go clinic before it dropped off.!!
