    Ordered load of Electrical parts from China and this was among them. WHAT is IT.? . . . . I've got an idea what it might be but lets see if you lot can figure what could be used for.?
ID:	18774Click image for larger version.
ID:	18775Click image for larger version.
ID:	18776Click image for larger version.
    Pic one looks like your lipstick that I have seen you with
    Don't be daft Clive, it's not Deans colour
    Crack pipe?
    https://emvioeng.com
    As it arrived with electrical goods I'm assuming it is electrical related?
    Is the pocket end for tinning large cable by creating molten solder container for dipping them in?
    Is the pointed end for splaying multicore cable out?
    So some kind of wire prep tool?
    Is the pointed end spring loaded or fixed or is it removeable? Does it look like it would fit into the pocket end
    ? Otherwise give us a clue . . .
    No there is hole thru the pointed end to the pocket so would run out.
    . . . . Too big would have to be large cable.
    Don't think so
    The red body is one piece aluminium the silver is plastic moulded to it which hold the black end caps.
    When together it looks decorative like Lipstick.!!
    Quote Originally Posted by komatias View Post
    Crack pipe?
    . . .. Close to what I'm thinking!!
    Dean,
    Do you actually know what it is ?
    Rob
    That's what I was going to say.!. . . . I use same colour as you Rob. .
  1. the mystery of the wonky corners
    By kingcreaky in forum Machine Discussion
    Last Post: 06-05-2014, 03:58 PM
  2. PC cannot find CD ROM ?
    By manofgresley in forum Computer Hardware
    Last Post: 06-12-2013, 02:35 PM
  3. Replies: 3
    Last Post: 24-11-2013, 02:36 PM
  4. mystery motor??? what is it for???
    By jonnydeen in forum General Electronics
    Last Post: 20-07-2012, 12:19 PM
  5. Mystery Profile, Please Help!
    By floydpjasper in forum Machine Discussion
    Last Post: 10-03-2012, 06:27 PM
