Thread: Mystery Find what is it.??
Crack pipe?
https://emvioeng.com
25-06-2016 #2
As it arrived with electrical goods I'm assuming it is electrical related?
Is the pocket end for tinning large cable by creating molten solder container for dipping them in?
Is the pointed end for splaying multicore cable out?
So some kind of wire prep tool?
Is the pointed end spring loaded or fixed or is it removeable? Does it look like it would fit into the pocket end
? Otherwise give us a clue . . .
25-06-2016 #3
No there is hole thru the pointed end to the pocket so would run out.
. . . . Too big would have to be large cable.
Don't think so
The red body is one piece aluminium the silver is plastic moulded to it which hold the black end caps.
When together it looks decorative like Lipstick.!!Last edited by JAZZCNC; 25-06-2016 at 10:08 AM.
Some sort of oiler or grease. I give up its too warm here
25-06-2016 #5
25-06-2016 #6
Dean,
Do you actually know what it is ?
Rob
25-06-2016 #7
25-06-2016 #8
You'll be needing some smoker's gauze or foil with lots of pin holes in it by the looks of that ;-)
25-06-2016 #9
25-06-2016 #10
Is the knob end spring loaded ? Seriously !
Rob
the mystery of the wonky corners
By kingcreaky in forum Machine DiscussionReplies: 19Last Post: 06-05-2014, 03:58 PM -
PC cannot find CD ROM ?
By manofgresley in forum Computer HardwareReplies: 3Last Post: 06-12-2013, 02:35 PM -
Residual Stress in Glass - Mystery of Prince Rupert's Drop at 130,000 fps
By AndyGuid in forum General DiscussionReplies: 3Last Post: 24-11-2013, 02:36 PM -
mystery motor??? what is it for???
By jonnydeen in forum General ElectronicsReplies: 10Last Post: 20-07-2012, 12:19 PM -
Mystery Profile, Please Help!
By floydpjasper in forum Machine DiscussionReplies: 3Last Post: 10-03-2012, 06:27 PM
