18-02-2018 #28
I'll just put this here for now, but it's a work in progress. I need to go and do something, but will try and get it finished later.
Original code-
Code:;============================================================================= MainStage ;============================================================================= ;Do gather if commanded (uncomment and recompile for debugging purposes) ;IF Aux11Key || ((SV_MPU11_ABS_POS_2 < SV_MACHINE_PARAMETER_45) && (SV_MACHINE_PARAMETER_45 < -1000)) THEN (Aux11KeyPD) ;IF Aux11KeyPD THEN (SV_TRIGGER_PLOT_DUMP), SET SV_STOP ;IF Aux11Key || OUT25 THEN (SV_TRIGGER_PLOT_DUMP) IF TRUE THEN CurrentTurretPosition_W = 0 IF ToolBit1 && ToolBit2 && !ToolBit3 THEN CurrentTurretPosition_W = 1 IF !ToolBit1 && ToolBit2 && !ToolBit3 THEN CurrentTurretPosition_W = 2 IF !ToolBit1 && !ToolBit2 && !ToolBit3 THEN CurrentTurretPosition_W = 3 IF ToolBit1 && !ToolBit2 && !ToolBit3 THEN CurrentTurretPosition_W = 4 IF ToolBit1 && !ToolBit2 && ToolBit3 THEN CurrentTurretPosition_W = 5 IF !ToolBit1 && !ToolBit2 && ToolBit3 THEN CurrentTurretPosition_W = 6 IF !ToolBit1 && ToolBit2 && ToolBit3 THEN CurrentTurretPosition_W = 7 IF ToolBit1 && ToolBit2 && ToolBit3 THEN CurrentTurretPosition_W = 8 IF TRUE THEN SV_PLC_CAROUSEL_POSITION = CurrentTurretPosition_W IF SV_PROGRAM_RUNNING THEN (ProgramRunning) ;cnctch.mac IF OnAtPowerUp_M THEN RequestedLocation_W = CurrentTurretPosition_W IF TRUE THEN TurretTimer = 700, ReversingTimer = 1500 IF M6 THEN (M6PD), SET DoingTurretIndex_M IF M6PD THEN RequestedLocation_W = SV_TOOL_NUMBER IF DoingTurretIndex_M && ((SV_TOOL_NUMBER < 1) || (SV_TOOL_NUMBER > 8)) THEN SET OtherFault_M, FaultMsg_W = INVALID_TOOL_NUMBER, RST DoingTurretIndex_M, RequestedLocation_W = CurrentTurretPosition_W, SET ToolChangeComplete IF DoingTurretIndex_M && RequestedLocation_W != CurrentTurretPosition_W THEN SET TurretMotor IF RequestedLocation_W == CurrentTurretPosition_W THEN SET TurretTimer IF TurretTimer THEN RST TurretMotor, SET ReversingTimer, RST TurretTimer IF ReversingTimer THEN RST ReversingTimer, SET ToolChangeComplete IF !SV_PROGRAM_RUNNING THEN RST M6, RST DoingTurretIndex_M, RequestedLocation_W = CurrentTurretPosition_W IF !M6 THEN RST ToolChangeComplete, RST TurretTimer IF SV_STOP THEN RST TurretMotor, RST TurretTimer, RST ReversingTimer, RST M6
Code in the process of being modified
RequestedLocation_WCode:;============================================================================= MainStage ;============================================================================= ;Do gather if commanded (uncomment and recompile for debugging purposes) ;IF Aux11Key || ((SV_MPU11_ABS_POS_2 < SV_MACHINE_PARAMETER_45) && (SV_MACHINE_PARAMETER_45 < -1000)) THEN (Aux11KeyPD) ;IF Aux11KeyPD THEN (SV_TRIGGER_PLOT_DUMP), SET SV_STOP ;IF Aux11Key || OUT25 THEN (SV_TRIGGER_PLOT_DUMP) IF SV_PROGRAM_RUNNING THEN (ProgramRunning) ;cnctch.mac IF OnAtPowerUp_M THEN RequestedLocation_W = CurrentTurretPosition_W IF TRUE THEN TurretTimer = 700, ReversingTimer = 1500 IF M6 THEN (M6PD), SET DoingTurretIndex_M IF M6PD THEN RequestedLocation_W = SV_TOOL_NUMBER IF DoingTurretIndex_M && ((SV_TOOL_NUMBER < 1) || (SV_TOOL_NUMBER > 8)) THEN SET OtherFault_M, FaultMsg_W = INVALID_TOOL_NUMBER, RST DoingTurretIndex_M, RequestedLocation_W = CurrentTurretPosition_W, SET ToolChangeComplete ;code to calculate distance to move If CurrentTurretPosition_W > RequestedLocations_W THEN DistanceToMove = ... (need to handle roll over) ;code to rotate A-axis require distance ;code to reverse A-axis IF TRUE THEN SET ToolChangeComplete IF !SV_PROGRAM_RUNNING THEN RST M6, RST DoingTurretIndex_M, RequestedLocation_W = CurrentTurretPosition_W IF !M6 THEN RST ToolChangeComplete, RST TurretTimer IF SV_STOP THEN RST TurretMotor, RST TurretTimer, RST ReversingTimer, RST M6
Chaz, to save me looking it up, just to confirm, it's an 8-position turret (45 deg between tools)?
And does normal rotation increase or decrease tool position?Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Centroid Acorn DIY CNC controller
By NB70 in forum Control Hardware & SystemsReplies: 3Last Post: 15-11-2017, 02:14 PM -
Centroid Acorn CNC Controller
By wallyblackburn in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 29-10-2017, 12:28 PM -
Controller Cabinet
By cropwell in forum Workshop & EquipmentReplies: 2Last Post: 19-12-2015, 02:23 PM -
FOR SALE: Controller Box for sale
By lateAtNight in forum Items For SaleReplies: 12Last Post: 04-03-2012, 10:17 AM -
Controller Box
By M250cnc in forum Motor Drivers & ControllersReplies: 1Last Post: 21-11-2010, 01:34 AM
