    Hello All
    I've just taken the plunge and bought a Leadshine MX3660 all in one box. The manual recommends using a shunt regulator/ capacitor to stop back voltage? blowing up the stepper drivers in an e stop situation. Does anyone know of the values of the capacitor required (48 volt switching power supply 3 x Nanotec ST6018L3008-A 4.3V 3.0amp stepper wired in parallel ) Or does any one have a circuit diagram of a shunt regulator that I could make. Also would it be better to use a non switching power supply transformer caps and rectifier ?
    Thanks in advance
    Andrew
    Quote Originally Posted by the great waldo View Post
    Thanks in advance
    Yes this is what you require. Switching PSU isn't recommended for CNC because the back EMF from steppers can cause you trouble with PSU protection shutting the unit down.
    Toroidal transformer with caps & Rectifier is what you require for best operation.
    Hi Jazz
    Thanks for the reply. I read somewhere that a 4700uf Cap should be put across the + - volt out from supply. Would that be needed as well as with a non switching power supply or could that be part of the smoothing circuit in the psu maybe upping the values of the Capacitors. It's been years since I did much electronics stuff mainly audio projects from everyday electronics and electronics today mags !!
    Andrew
    Capacitors are the smoothing/shunt circuit and the PSU output you require will determine the Capacitance required.
    I think the MX3660 uses 60Vdc drives so you'll not want much more than 50V output and if using 4A motors you'll require aprox 8A output for 3 x motors(65% total amps).
    So Transformer with 2 x 18Vac secondarys wired in series and 300Va will give you aprox 50V with 8.3A or if require more amps go with 500Va for just under 14A.
    With 300Va you'll get away with 2 x 4700uf-80 or 100V Caps wired in parallel but for the little extra they cost I'd go with 3 x 4700uf to give that bit more smoothing.
    25A or 35A Rectifier.
    Hi Jazz
    Thanks very much for the info. I had just checked out this transformer http://www.trafoshop24.de/rk-transfo...-rk-ec500.html Is there any benefit from using toroidial as opposed to the old square transformers from back in the day ?
    Andrew
  6. Quote Originally Posted by the great waldo View Post
    Hi Jazz
    Andrew
    Advantages of toroidal transformers is pretty much weight, efficiency, reduced em field and, typically, cost. They come with a bit of a disadvantage of high-inrush current, but that can either be ignored or designed-out.
  7. Leadshine makes a shunt regulator specificaly for this.
    https://www.zappautomation.co.uk/sr5...regulator.html
    You can use a switching supply with a stepper system, but they are not ideal, but if you do, use a nonregulated switching supply. like the sps type.
    Hello All
    Thanks in advance
    Andrew
    Thank you Gary
    I'll be going with a nonregulated supply. Just out of interest what is an sps type ?
    Andrew
  9. Like this.
    https://www.zappautomation.co.uk/sps...er-supply.html
    Thank you Gary
    Andrew
    Hi Gary.
    Thank you.
    Andrew
  1. Replies: 7
    Last Post: 15-07-2018, 08:41 PM
  2. Configuring Altivar 12 frequency regulator for PID control
    By vesilp in forum Spindles & Drive Motors
    Last Post: 28-01-2017, 04:26 PM
  3. Wiring Limit switches to Leadshine MX3660
    By thomashomer1986 in forum Motor Drivers & Controllers
    Last Post: 07-01-2016, 08:05 PM
  4. FOR SALE: Servo motor with 26:1 Gear box, EPOS controller and Power shunt unit
    Last Post: 30-05-2011, 11:03 PM
  5. Panel Mount Voltage Regulator / Knob
    Last Post: 29-11-2008, 01:23 AM
