Thread: MPG has stopped working
Hi Brian,
I had once a problem, most probably related to the CSMIO IP-M controller plugin. Without doing anything wrong, one day just stopped communicating properly some inputs. I have tried a lot of things but only reinstalling Mach3 solved the problem. If you reinstall, make sure to copy your xml profile file, macros, plugins and controller settings.
19-12-2018 #2
Thank you for replying.
Instead of reinstalling Mach3, I tried to "Restore Settings..." under "Operator". Guess what, it worked
I then replaced my XML file with a backup I made just before I did the restore. Then the pendant didnīt work again, so the XML must have been corrupt, which means that it probably would have been futile to reinstall Mach3 and use the backup.
I hope this can help others and from now on I will always have multiple backups of my working XML profile on different drives.Last edited by CNCDev; 19-12-2018 at 07:11 PM.
3.0Nm stepper from Zapp stopped working / faulty
By Jonathan in forum Stepper & Servo MotorsReplies: 8Last Post: 10-05-2017, 08:59 PM -
china 40W Co2 laser stopped cutting
By Ross77 in forum Laser Machines & BuildingReplies: 0Last Post: 06-05-2017, 08:37 PM -
NEW MEMBER: Hi, I'm working on Cheap CNC
By CNCKitMan in forum New Member IntroductionsReplies: 10Last Post: 08-02-2017, 01:40 AM -
Z drive not working
By whensparksfly in forum General ElectronicsReplies: 3Last Post: 14-04-2016, 09:14 PM -
x&z not working
By cncjohn in forum Linear & Rotary MotionReplies: 5Last Post: 18-08-2013, 12:58 PM
