14-01-2010 #14
That does sound a bit excessive :nope:
The place I came unstuck was the first time I encountered a G0 suddenly hammering the X axis in to reverse, the worst possible case when it comes to losing steps on a motor, even though you can ignore the cut pressure. My software just threw one in at the cut start, out of the blue, just for fun.
I eventually set an 'okay to hammer in to reverse' threshold, that exempted most normal cutting from accelerations, then gave it a quarter turn acceleration time on the G0's.
Setting the top speed is a bit suck it and see, but you can get an indicator by looking at the torque v speed curve for the motor to see where it starts to plummet.
I need to be a big comfort zone on the G0 speed. Having fitted new super 220V drivers to my machine it would probably be good for 25 mm/s plus, but I still have it set to 10 mm/s. I know it would work fine if I ramped it up, but I just haven't found a job yet where I don't mind risking the metal to find out :naughty:
Holding down sheet material.
By jcb121 in forum Machine DiscussionReplies: 3Last Post: 03-07-2013, 12:11 AM -
How to cnc cut 1-2mm stainless sheet ??
By Ricardoco in forum Metalwork DiscussionReplies: 9Last Post: 28-03-2013, 04:06 AM -
THC lifting off sheet?
By lockyg in forum Machine DiscussionReplies: 2Last Post: 06-12-2012, 04:56 PM -
3mm sheet brass
By cropwell in forum Marketplace DiscussionReplies: 1Last Post: 17-10-2012, 09:55 AM -
Motorcalc sheet ...
By Wobblybootie in forum General DiscussionReplies: 2Last Post: 13-01-2010, 06:27 PM
