Page 1 of 3 123 LastLast
    Hello All, I'm back again and still haven't finished my machine! Anyway, I'm just looking to purchase the steppers and came across these:-
    https://www.ebay.co.uk/itm/Dual-Shaf...QAAOSwHu5b5ADz
    They look almost identical spec to the 3.1Nm ones currently on CNC4You that I saw recommended elsewhere, well all apart from the Voltage?
    https://www.cnc4you.co.uk/Stepper-Mo...YGH301B-Nema23
    It says voltage of 24-48 volts in the spec but my Toroidal power supply should be around 70v when I actually assemble it. Are they a different motor and therefore not suitable?
    Cheers,
    Charlie
    Lives in East Lothian, United Kingdom. Last Activity: 4 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Going by the key spec (current and inductance), they are pretty much identical motors.
    However I'd say 70V is too high. The recommended max voltage is 32 * SQRT(L) (L is inductance), which puts the recommended max voltage around 57VDC when running with parallel/unipolar wiring.
    A higher voltage won't have much effect at lower speeds, however if you're running at higher speeds, overheating is likely to become an issue if running at the rated current.
    Thanks for the reply, I probably should of said I plan on connecting them in series so the max voltage works out at 114v given the above formula unless there is a reason not to connect in series🤔
    Charlie
    You'll get better performance for any given voltage using parallel.
    Inductance is the killer of performance, which is why you normally want steppers with as low an inductance as possible.
    Am I looking at this all wrong? I'm thinking of getting the EM806 or AM882 80v drivers, I have a 2 x 25v toroidal transformer and 4700mf 100v caps and rectifier to build the PSU which should deliver 68v, I am scratching my head at what stepper motors I should get to match the Power supply....if those 3.1Nm steppers only require 57v would I be better to go for 50v drivers and a smaller PSU?
    Quote Originally Posted by CharlieRam View Post
    Personally I would go with the 68V p/s with the drives above or https://www.ebay.co.uk/itm/2DM860H-2...frcectupt=true
    There are plenty of people using this setup without problems
    Clive, Are you saying the 57v rated Steppers will be fine with the 68V PSU and either of those drivers? I am sure this is what people have used in the past but m_c says the voltage is too high! I'm a little confused now.
    I saw those drives but was a little unsure....have many people used them? It doesn't look like it has stall detection although I do understand that if the motor has stalled the job will be wrong even with stall detect.
    It's worth doing the sums and working out exactly what voltage you need - for some motors 50V would be fine, for others a big hindrance. Thankfully, @Irving2008 has put it all into a handy-dandy spreadsheet which ties together all the variables (apart from using pulleys/gears with a non 1:1 ratio) for which he deserves a beer - go looky here:
    http://www.mycncuk.com/threads/1524-...tor+calculator
    This is part of my problem...the spreadsheet says the motor has a good margin but will it be ok on a 70v power supply?? Click image for larger version.
    I have always used 68 V with no troubles, everybody has their own opinion so you have to make your own mind up.
    I found them about 2 years ago and have used about 8 of them Dean (Jazzcnc) I think has used more than 12. re the stall detect you are correct they don't have it. But the AM882 and EM806 does have it but if I remember correctly it only kicks in at about 300 rpm.
    As m_c has stated go with a parallel setup.
  1. Powering 3 45Ncm Nema 17 Stepper Motor 2A 4-wire (not CNC)
    By Fivetide in forum Stepper & Servo Motors
    Last Post: 22-11-2016, 01:32 AM
  2. FOR SALE: Nema 34 12Nm stepper motor
    By dsc in forum Items For Sale
    Last Post: 08-05-2014, 01:14 PM
  3. FOR SALE: Nema 23 4Nm Stepper Motor
    By Shinobiwan in forum Items For Sale
    Last Post: 07-02-2013, 02:15 PM
  4. Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
    By LoveLearn in forum Gantry/Router Machines & Building
    Last Post: 08-02-2012, 01:52 AM
  5. Stepper motor advice for absolute novice
    By mbgnjdb5 in forum Stepper & Servo Motors
    Last Post: 07-05-2011, 04:47 PM
