    RobC's Avatar
    Lives in Leeds, United Kingdom. Last Activity: 10-04-2026 Has been a member for 8-9 years. Has a total post count of 118. Received thanks 16 times, giving thanks to others 21 times.
    It's also no showing any detection on it. It's driving me mad as sure as I am it should be working and nothing is displaying/triggering. I'm going off past questions and what others have said to check regarding volt drops when triggered. Yeah everything has worked fine for months but I've just got round to sorting this E-stop issue out.
    Lives in Marple Stockport, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by RobC View Post
    You have not answered Rob's question re the 12-24v on the bob also do you have the correct port set in Mach3. Should the e-stop be connected between grd and pin 10
    RobC's Avatar
    I did it's in there with the its been working fine. E stop is wired between ground and 10 as described above. It's set to port 1.
    Well it seems you don't wan't to answer questions. No one has a crystal ball. re. "I've got 5.5v between pin 4 and pin 10," I don't think that is the correct place to get the 5v The inputs should show about 5V between a pin and ground. The reason for asking if the 12-24V is connected is that the inputs pins won't work without it.
    RobC's Avatar
    Well you directed at myself as you declared I've not answered my own question (Rob which is me), a little confusing. As I've said before I'm going off what others have declared to measure between on previous posts and yes the 24V is connected and into the correct pins.
    Hi RobC,
    are any of the other inputs working ? Homes and limits that is.
    Rob-T
    RobC's Avatar
    Hello! Well I didn't rewire any in but I've just done so as an experiment and they trip the stop function no problem. So that got me thinking, I'll try wiring 24v straight across the E-stop and bypassing ground and that works fine so I've got that wired as such now to trip the E-stop.
    Ok I am not prepared to get into mind games. Good luck
  1. Looking for input
    By jtar40 in forum Motor Drivers & Controllers
    Last Post: 29-03-2018, 11:56 PM
  2. E-Stop input problem
    By eurikain in forum General Electronics
    Last Post: 21-02-2016, 08:31 PM
  3. New build – input/comments appreciated
    By ngundtoft in forum Gantry/Router Machines & Building
    Last Post: 05-10-2015, 11:38 AM
  4. Help re electrical input
    By Jomach21 in forum Motor Drivers & Controllers
    Last Post: 08-06-2015, 12:30 PM
  5. Haunyang VFD input voltage
    By JamesUS in forum Spindles & Drive Motors
    Last Post: 18-01-2015, 08:25 PM
