14-04-2019 #11
14-04-2019 #12
I ordered a second one as a means of maybe outright swapping this one, other than that I'ts not been too bad! I've had endless issues with mach and it doing random things like stalling on a G21 command making me restart the program to solve it. Now you've got me working on putting in my limit switches again as I've been working on where I knew it would crash and then making my work well within such limits.
14-04-2019 #13
I'm endlessly amused by the things Mach3 "refuses to do" :D
14-04-2019 #14
If I wasn't so broke with flying real planes I'd of long moved on from it, really fed up with the little issues I have with it!
14-04-2019 #15
I use Mach3, all the issues I've ever had with it were about me, not about Mach3, which is the thrust of my comment :D
My new machine has a Siemens controller, Servos and Drives ;-)You think that's too expensive? You're not a Model Engineer are you? :D
15-04-2019 #16
Looking for input
By jtar40 in forum Motor Drivers & ControllersReplies: 0Last Post: 29-03-2018, 11:56 PM -
E-Stop input problem
By eurikain in forum General ElectronicsReplies: 9Last Post: 21-02-2016, 08:31 PM -
New build – input/comments appreciated
By ngundtoft in forum Gantry/Router Machines & BuildingReplies: 73Last Post: 05-10-2015, 11:38 AM -
Help re electrical input
By Jomach21 in forum Motor Drivers & ControllersReplies: 1Last Post: 08-06-2015, 12:30 PM -
Haunyang VFD input voltage
By JamesUS in forum Spindles & Drive MotorsReplies: 0Last Post: 18-01-2015, 08:25 PM
