You are correct in that nema34 motors usually don't give you the required performance increase above nema24 motors.
In all honesty, given the speed you're looking for, I'd look at servos.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
02-06-2019 #2
02-06-2019 #3
Hi Matthew
Just to clarify Robin’s earlier comment. You are not offending anyone here. Far from it, you are asking interesting questions. Robin was referring to new posts from builders who come on this site having bought some big motors and are sometimes offended when told they have bought the wrong thing. It has happened a lot.
03-06-2019 #4
Aliexpress.
I've not personally used them (I opted for Kinco from Zapp), however at least a couple people on here have used the cheap Chinese servos without any problems.
Drive/Motor set can be had for under $300.
The main drawback is the drives are only powered via the 240VAC, so if they lose power, you lose position. Whereas the logic in the Kinco drives is powered via 24VDC, so you can cut the 240VAC (i.e. an estop) and all the encoder circuitry remains active.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
03-06-2019 #5
Thank you, I understand, I think I must have misunderstood originally - I definitely didn't want to be putting anyones nose out of joint, especially after having had such good advice on here in the past.
Thank you, it's definitely worth thinking about - I started learning a little more about servo motors after I saw your reply. All this time I was under the impression they all had a built in gearbox like those servos you get in model-aircraft and RC-cars, but that doesn't seem to be the case!
05-06-2019 #6
Hey Guys,
My apologies, I think I've made some real errors of judgement above! I'm still very much an amateur but here's what I think is happening for anyone that reads this and gets as confused as I did, in the future:
A coil in one phase will have current go from all in the +ve direction, through 0, to all in the -ve direction, and then back through 0 to +ve again in one revolution of the motor. In the case of a 4.2A motor it has a total of 16.8A to move (+4.2A --> -4.2A --> +4.2A) - so massminds worse-case calculation I linked to in an earlier post, I think, is correct after all (although in contradiction to the calculation on All About Circuits website - how?).
For my motor (I=4.2A, L=3.2mH, V=68V) I thus get a max speed of 380RPM. The first time I calculated this it didn't feel right so I did more reading and convinced myself that my gut was right (that 759RPM should be my max). Reading the info on the All About Circuits website seemed to persuade me of this - but it didn't expain why the graphs on some spec sheets for motors were shown with usable torque at even higher speeds.
BUT, it just dawned on me that this (380RPM) is the CORNER SPEED, NOT the MAX SPEED!! This is the speed under-which the coil should be able to fully saturate (build the maximum field strength) in both directions and thus maintain full torque (or very near to) upto this speed. This is what Geckodrives graphs show with the flat portion: https://www.geckodrive.com/support/s...or-basics.html
At speeds faster than 380RPM there is fall-off in torque because there is no longer time to fully saturate the coil with the maximum current. Torque drops off after this speed because its proportional to current and reaches its max speed when insufficient current can be pushed into the motor to make a step.Last edited by mattnedgus; 05-06-2019 at 05:00 PM.
08-06-2019 #7
Tech:
Yes, no.
Steppers are not much different from servos.
The servos step up the "next" step magnetically before the rotor is there.
They anticipate the position of the rotor and tightly couple it to the angle of the rotor via the encoder.
And using the skewed rotors (afaik) +magnets they can keep this up indefinitely.
And can use very heavy currents temporarily, since the duration is so short.
Servos used to run 12 kHz, 0.1 ms each.
But servos have better magic steel and magic wire.
Very complex thing with magnetic flux rise time, decay time, heat losses, efficiency, mag. flux strength, inductance, reluctance, etc.
The servos have probably 1% difference in materials but might have 100x difference in terms of magnetic inductance/reluctance effects at very high speeds == 500 kHz - 4 Mhz of modern ac servos.
Dip Switch settings on the M542 stepper motor drivers
By manofgresley in forum Motor Drivers & ControllersReplies: 13Last Post: 04-01-2021, 09:10 PM -
3 wire stepper motor drivers?
By m_c in forum Stepper & Servo MotorsReplies: 0Last Post: 17-08-2013, 10:01 PM -
Stepper motor coil resistance. What is an acceptable value?
By gavztheouch in forum Stepper & Servo MotorsReplies: 3Last Post: 30-11-2012, 05:53 PM -
Setting up stepper motor drivers
By croy in forum Motor Drivers & ControllersReplies: 25Last Post: 30-09-2012, 09:51 PM -
eBay Stepper Motor Drivers from China
By Mad Professor in forum General ElectronicsReplies: 6Last Post: 20-07-2009, 10:54 PM
