Thread: Cnc adventure Vol.1
04-08-2019 #6
Hi Andy
Yep,Aluminum plates,not steel,typing error.
Yes,that would be option 2,I would have to make a 15mm spacer to mount everything together.
Option one is preffered,since milling two faces would not cost a fortune,if I go with handcutting alu plates,and It would reduce overhang by 15mm.I’ve put 240mm long gantry sideplates versus 280mm you did.I’ll have to finish z axis (spindle and mount)and run center of mass analysis,so then I’ll see where I am,if is needed to elongate sideplates or not.
Well steel frame didn’t seem that big of a hassle.I’ll check both options!Thanks for that.
If alu is chosen,kiln dryed sand is an option if resonance and vibratins occur as Lee sugested.
Yes its a bit offcentre so when ballnut and mounting bracket are connected nothing is sticking out of that T bracket,but yes I can beef it up a bit.
Andy you used 2010 ballscrew,so do I in this stages,but did you consider 1610 and making it both sides fixed?Did anybody do that?Rotational mass would be significantly lower with 1610.��
Never went in calculating critical speed for 1610 in fixed fixed arrangement,but I will,just to see what would be results in comparison to 2010 ballscrew in fixed/supported arrangement.Last edited by Scustom; 04-08-2019 at 10:42 AM.
NEW MEMBER: Computing student on machining adventure!
By Megamolis in forum New Member IntroductionsReplies: 0Last Post: 24-03-2016, 05:22 PM -
Jcb water cooling adventure part two.
By jcb121 in forum Metalwork Project ShowcaseReplies: 5Last Post: 04-07-2014, 07:46 PM -
BUILD LOG: The B&Q build adventure begins....
By flez1966 in forum DIY Router Build LogsReplies: 3Last Post: 11-10-2009, 01:48 AM
