26-09-2019 #9
Aye, I can see that dust etc. might be a problem and was thinking of a cover to minimise that.With a suitable cable (starquad or high current coaxial) I don't think the current flow in the power line would be too much of an issue.
The biggest problem I can see is that you are replacing the nice short signal cables between your controller and the drivers by several metres of 'antenna' wiring which will have to run alongside the still noisy stepper driver power cabling and the VERY noisy spindle power cabling from your VFD. It might be case of frying pans and fires in spite of your best efforts at screening. But please don't stop thinking out loud!
In my controller the break-out is mounted inside it's own screening box and has short screened cables running to the drivers leaving only about 20mm of exposed wiring. The output cables are deliberately routed away from the inputs to minimise coupling. I've cut the motor's own wires quite short and use screened cable to connect back to the drivers with all the cable screens connected only at the controller end. Limit switch inputs have 1uF capacitors across them to prevent noise-induced false triggering. I haven't had any problems since upgrading the controller to this design.
KitLast edited by Voicecoil; 26-09-2019 at 01:08 AM.
Has anyone please got an idea where I could get a bolt like this?
By suesi34e in forum Marketplace DiscussionReplies: 31Last Post: 13-01-2015, 01:06 AM -
Website idea.
By qwertyjon in forum General DiscussionReplies: 18Last Post: 11-07-2014, 08:49 PM -
Website idea.
By qwertyjon in forum General ComputingReplies: 8Last Post: 05-04-2014, 03:29 PM -
crazy idea
By kingcreaky in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 27-08-2013, 07:54 PM -
BUILD LOG: Mel's Odd Idea
By mel_earp in forum DIY Router Build LogsReplies: 3Last Post: 19-03-2010, 11:54 AM
