Thread: Suitable cable chain
06-12-2019 #2
In my experience, wider is much easier. You can run out of room fast.
An important consideration is bend radius. You don't want too small / tight radius as it's bad for cables (radius needs to be bigger than minimum specified for all cables you use), too big and it can be a problem fitting the cable chain. Too big is most commonly a problem on the Z axis.
The Following User Says Thank You to pippin88 For This Useful Post:
Chain drive
By eurikain in forum Linear & Rotary MotionReplies: 7Last Post: 15-07-2015, 01:37 PM -
Cable drag chain
By birchy in forum General ElectronicsReplies: 9Last Post: 04-01-2014, 12:45 AM -
The Dragon Cable Chain
By motoxy in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 12-02-2012, 03:20 PM -
FOR SALE: Wanted: E-Chain
By D-man in forum Items For SaleReplies: 0Last Post: 26-01-2011, 07:02 PM -
Plastic link chain cable carrier.
By adscnc in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 11-12-2009, 06:35 PM
