Thread: CSMIO/IP-M and PM752 Drivers
Whilst I remember the spindle wiring worked perfectly. Here's a quick demo:
My CNC Projects: https://www.youtube.com/imadethisoncnc
27-01-2020 #2
27-01-2020 #3
Not sure - the sound is generally bad on the camera and its also mounted directly to the spindle/bearing mount. The spindle is fairly new and does make a bit more sound than the one I had previously, but it doesn't get hot or anything, so I assume its OK (pulls about 1.8 to 2.1 amps under load). The hole is also drilling through the stock into the sacrificial bed for indexing purposes and the drill will be catching on one peck at lest on the double sided tape under there (plus some other detritus in previous cut throughs).
Just about to head down to the workshop to try the pulse edge thing, but I also notice in my drive manual/datasheet that there are 4 jumper settings to choose from:
I'm assuming that "a" is default, so I probably need "b" (or vice versa depending on what I find in there and assuming I don't set it in MACH4)?My CNC Projects: https://www.youtube.com/imadethisoncnc
27-01-2020 #4
Yes that's the drive setting for switching leading edge but just do it in mach4 it's easier.
Regards the noise then I wasn't meaning the sound of the spindle, it sounded clunky in its movement as if a coupler or pulley something was loose, possibly dodgy bearing. I'd be checking out the Z axis as well. You would get the same problem if something was slipping.
CSMIO/IP-A Controller
By D-man in forum CS-Lab (CSMIO)Replies: 5Last Post: 07-01-2019, 09:08 PM -
help needed with CSMIO/IP-M
By terry1956 in forum CS-Lab (CSMIO)Replies: 2Last Post: 18-11-2018, 07:20 PM -
FOR SALE: Cs labs csmio ip-s
By Web Goblin in forum Items For SaleReplies: 3Last Post: 22-07-2018, 08:45 PM -
csmio/ip-m z probe
By charlieuk in forum CS-Lab (CSMIO)Replies: 0Last Post: 16-09-2017, 09:49 AM -
eBay: 3 x PM752 Microstepping Drivers
By Iwant1 in forum Items On eBay UKReplies: 18Last Post: 24-08-2012, 11:47 PM
