  1. #14
    Lives in Plymouth, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    If it's this pulse edge problem - certainly sounds like it! - then you can either swap over the "step" connections at one end (IP/M or driver) or change the "active high/low" setting for the step pulses in Mach4. I'm assuming that it has a setting for that, just like Mach3. I had this problem on my Z axis which is why it didn't show up for a while - you see the problem when there are lots of direction changes on that axis and for mainly profile cutting, there aren't many on Z.
  2. The Following User Says Thank You to Neale For This Useful Post:
  1. CSMIO/IP-A Controller
    By D-man in forum CS-Lab (CSMIO)
    Last Post: 07-01-2019, 09:08 PM
  2. help needed with CSMIO/IP-M
    By terry1956 in forum CS-Lab (CSMIO)
    Last Post: 18-11-2018, 07:20 PM
  3. FOR SALE: Cs labs csmio ip-s
    Last Post: 22-07-2018, 08:45 PM
  4. csmio/ip-m z probe
    By charlieuk in forum CS-Lab (CSMIO)
    Last Post: 16-09-2017, 09:49 AM
  5. eBay: 3 x PM752 Microstepping Drivers
    By Iwant1 in forum Items On eBay UK
    Last Post: 24-08-2012, 11:47 PM
