    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 09-02-2025 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
    A lot of this V2 is sales hype. Don't take any notice of things like the Resume after power-down features because while it does do exactly that it never works out good because the print as cooled down so the new layer doesn't stick which makes virtually useless. The V1 also as this feature.
    The Dual gear filament head looks exactly the same as what's on my 10S but they have integrated the out-or-filament switch into the head by looks of it. Again this nothing special.
    The extruder looks pretty much the same but they have a switch type bed leveling sensor fastened to it. Again nothing special and could easily be added for a few Euro's.
    The main thing I see between the V1 and V2 is the base now houses the electronics which I wouldn't want if I'm honest. The heat of the bed and printing cannot be good long term for those electronics. Large prints take days and all the heat from printing will radiate down into that box. I much prefer my separate box.
    I wouldn't pay $200 more for the V2 I'd buy the 10S and upgrade it with the $200 saved, then you'll have a really great machine.
  1. Cheap reliable connectors
    By bluesking in forum General Electronics
    Last Post: 18-06-2019, 10:36 AM
  2. RFQ: Looking for a reliable CNC prototyper in aluminium, for lots and lots of jobs
    By Felix.U in forum Projects, Jobs & Requests
    Last Post: 01-12-2015, 02:00 PM
  3. Wanted - Regular work for reliable machine shop in Northants/Kettering area
  4. Looking for a reliable cheap linear system pls
    By psiron in forum Rails, Guideways & Bearings
    Last Post: 07-06-2010, 04:18 PM
