I would need to know more about the weights your moving and linear stage etc but any 200W AC servo would probably do what you need or 400W at most I would think. Even something like this 180W DC with integrated drive would be enough I'd guess, esp if used a gearbox.
https://www.ebay.co.uk/itm/180W-3000....c100005.m1851
Don't be fooled by the low Nm rating, Servo's are very different to steppers and the rating is constant across the RPM range so you'll have the rated Torque at full speed which is often 3000rpm, this is between 2x to 3x faster RPM than a stepper will reach which is why you can use a gearbox to increase torque and still have the same rpm as a stepper. Also, they can often peak at 3x the rated torque for 10-20s which is often more than enough to overcome any friction and get things rolling.
Hey Jazz, hope you had a good week. Just wondering if you saw my messages giving a bit more info about the build? I'd love your opinion about the correct driver for the NEMA 34 and PSU.
Thanks,
Max
