16-11-2021 #1
What do I need to configure on the VFD so that I can control spindle speed directly from the VFD? I can switch it on and off but it is set at 24k rpm and I would like to adjust that if necessary.
Thanks.
16-11-2021 #2
Does your VFD have a knob on it?
If it does, then that should work using default settings.
If it doesn't, I think the up/down arrows should work, provided you've not pressed any other buttons to enter any menus.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
17-11-2021 #3
Yes it has the knob. Turning it does nothing though. Pressing the up/down arrows also does nothing.
PD001 = 0
PD002 = 0
Maybe something else in the settings?
17-11-2021 #4
Pd002 =1 for external control and you need to set the jumper at the side next to the terminals to the opposite of what it's set to know, you will see 3 pins and a little black jumper bridging across 2 of them, just swap them around. This will enable or disable the pot on the front, so if some else has disabled it so they can control it from the control software this will set it back.
Email: [email protected]
Web site: www.jazzcnc.co.uk
24-11-2021 #5
Hi Dean, Managed to get it working using the pot on the front however the spindle only spins up to max 12,500 RPM. How do I get it to max 24k?
Thanks!
Edit: Just a note, when I set PD02 = 0 then it spins up to full speed (but then Im unable to adjust speed)Last edited by grantx; 24-11-2021 at 03:50 PM.
24-11-2021 #6
24-11-2021 #7
It has a single jumper currently sitting across VR.
How do I tell what voltage is being supplied?
24-11-2021 #8
This is from:-
http://www.mycncuk.com/threads/7388-...7099#post57099
The VFD has to have the parameters changed PD002 from 0 to 1 and PD070 from 0 to 1 (changes analogue from 0-10 to 0-5) without this the speed only goes up to 12K...Clive
24-11-2021 #9
25-11-2021 #10
Hi Grant,
Just replied to your email but notice here that Clive got ya going, he's a little super star.
Huanyang with axbb vie Mach 3 only work at 1 speed.
By Paul001 in forum Generic Chinese SpindlesReplies: 9Last Post: 03-09-2021, 07:47 AM -
Huanyang HY02D223B VFD Question
By iforeman in forum General DiscussionReplies: 2Last Post: 26-10-2017, 05:00 PM -
Wiring Huanyang HY02D223B
By Stan in forum Milling Machines, Builds & ConversionsReplies: 21Last Post: 25-03-2017, 07:25 AM -
Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
By Mad Professor in forum Spindles & Drive MotorsReplies: 34Last Post: 01-10-2016, 10:21 AM -
Huanyang hy02d223b frequence convertor problem
By frans cop in forum Motor Drivers & ControllersReplies: 3Last Post: 14-07-2015, 10:33 AM
