15-09-2008 #41
OK are the spped you running at between 70 and 100 steps a second? if so the problem could be resonance.
Try it with load and see if the the problem is still there.Visit Us: www.automationshop.co.uk
15-09-2008 #42
So I've finally got my motors running smoothly on the Mach 3 but I've hit yet another problem.
Every so often the motors will stall for no apparent reason. I first thought the lead screws where getting jammed but I've even tried the motors without any load and they still stall.
When the motors stall even if I try to help it to move forward it won't. But the moment I release the jog key and start jogging again it works fine.
Jog at slower speeds causes it to stall less but it does stall. Also when jogging at slow speeds I can hear the motor sometimes hesitate.
See the video or a fast and slow jogging X axis without it being connected.
P.S> I don't know what's the BBCode to embed YouTube Videos in this forum.Last edited by Lee Roberts; 25-10-2019 at 11:10 PM.
15-09-2008 #43
At the moment Mach3 is set to 1000 Steps per mm. The problem is both with and without load.
15-09-2008 #44
I've gone through exactly the same process as you Bruce. I have the MDS 542 drives, 3nm motors and PSU's from Zapp
I bought a laptop to use with Mach3, had nightmare issues with missed steps and stalling even while the motors were on the bench at very low speeds. I got in touch with Pminmo who was extremely helpful and got me at least working. Running on the bench was much better, in fact I was pushed to make the motors stall. Putting them on my machine however, I had to run at very low speeds to get smooth motion. I could jog the X maybe 150mm before it would miss or stall, jog again and it would be fine for maybe 500mm before missing or stalling, jog again and it might instantly stall, no set pattern.
In desparation I ordered a SmoothStepper from the states and what a transformation. Before, the best I could get from my Ballscrew X axis was 1000mm/min, now I'm up at 3000mm/Min and it could go faster comfortably but it seems fast enough for me to leave it set at. My rack and pinion Y axis, whose motor turns slowly, would stutter randomly, that is all gone now, smooth in all three axes. Just running Mach3 with the SS attached and no machine, the toolpath display seems smoother running.
I know this doesn't help you solve your problem but this little board has transformed my laptop controlled system and I'd bet it would do the same for you if you cannot cure your problem. At the end of the day Mach3 and Laptops have an uneasy relationship and even if you get yours optimised to the Nth degree, I feel it will always be marginal. Cost me £130 total with all taxes but worth every penny. I know I could buy a S/H desktop for the same money and probably have zero troubles but I don't have the option of using one, I simply HAD to use a laptop because a desktop could not survive for long where it would be living.
Worth thinking about.Nothing is foolproof......to a sufficiently talented fool!
15-09-2008 #45Visit Us: www.automationshop.co.uk
15-09-2008 #46Visit Us: www.automationshop.co.uk
15-09-2008 #47
How do I figure out what the linear speed is, as mentioned I'm seeing this both at slow jog (i.e 35%) and full jog.
My resolution is still set at half step i.e. 2
16-09-2008 #48
I dont use Mach 3, but if it is set to 1000 steps per mm and you run at 35% of full speed, you need to work back from that.
the motor is set to 400 steps per rev.
If you are set to 35%, what is you max speed set to?Visit Us: www.automationshop.co.uk
16-09-2008 #49
This is what Mach3 is set at 1000 step per mm for the x and y axis at 600mm/min and acc of 200
16-09-2008 #50
Anyone with any other help? I'm really getting desperate to get this machine going.
Use of microstepping, external motion control boards, and related issues
By Neale in forum General ElectronicsReplies: 0Last Post: 11-06-2014, 12:17 PM -
Leadshine 4-axis motor motion control cards? Any experience and info?
By Boyan Silyavski in forum Motor Drivers & ControllersReplies: 0Last Post: 02-12-2013, 06:43 PM -
CNC Motion control
By StoneyCNC in forum Manufacturer NewsReplies: 1Last Post: 26-08-2013, 10:07 AM -
2x Motors, 2x drivers. How about breakout?
By Tenson in forum Motor Drivers & ControllersReplies: 2Last Post: 20-09-2012, 03:21 PM -
Time for a purpose built motion control computer.
By GeoffV in forum General ComputingReplies: 17Last Post: 08-11-2010, 01:11 AM
