Thread: HY VFD DCM connection
11-05-2022 #14
The reason I would use a relay is because when I worked in industry that was the standard method for a reason and I liked it, same thing with PLC's
It was found that if a fault developed it was cheaper, easier, quicker, to replace a small plugin relay than a VFD, PLC, or the device controlling it.
Galvanic isolation with a set of "volt free" contacts would always be my solution, there can be some undesirable and unforseen results by connecting supposed "earths" together.Spelling mistakes are not intentional, I only seem to see them some time after I've posted
Xsy-at1 connection translation
By GREG021 in forum Motor Drivers & ControllersReplies: 4Last Post: 17-02-2021, 02:10 PM -
Which Connection ?
By manofgresley in forum Stepper & Servo MotorsReplies: 17Last Post: 13-07-2020, 01:55 PM -
Connection hub
By Agathon in forum General ElectronicsReplies: 9Last Post: 18-05-2020, 09:06 PM -
smoothstepper with ethernet connection
By terry1956 in forum Motor Drivers & ControllersReplies: 15Last Post: 22-02-2016, 03:22 PM -
Or Guidance ;) Connection Name(s)
By Carlb1058 in forum Marketplace DiscussionReplies: 6Last Post: 13-07-2013, 12:48 AM
