    Bridgeport Interact II Vertical CNC Machine - Converted to modern NEMA 34 stepper motors
    £1499 – Glasgow G209BT INC VAT!
    A bargin for a potentially very capable machine that could tackle many various industrial and hobby tasks.
    Bridgeport Interact II Vertical CNC Machine for sale.
    A solid, heavy-duty machine with plenty of potential, now set up to run from steppers
    The spindle is 3 phase but with an inverter it could run from a single-phase supply no problem...
    Perfect for someone looking for a capable heavy duty vertical mill with a robust spindle and upgraded motor setup.
    It also have a massive and solid bed with ample t slots.
    A large coolant tray is also included but not shown in the pictures.
    Key Features
    Bridgeport Interact II vertical CNC machine
    Can be used as Single-phase setup (with inverter - not included)
    Upgraded with NEMA 34 stepper motors
    Continuously variable spindle transmission
    Spindle speed range: 50 RPM to 3000 RPM
    Heavy-duty spindle with heavy duty bearings
    2 HP spindle motor
    Encoder upgrade possible (motor shafts are long enough)
    The spindle is a very heavy-duty unit with a strong bearing setup and continuously variable transmission, giving a useful speed range from 50 RPM up to 3000 RPM — suitable for a wide range of machining work.
    The spindle motor is 2 HP single phase, and can be run using an inverter drive for even more spindle speed control and enable single phase operation.
    Condition
    Sold as seen
    Good project / workshop machine
    Strong mechanical base
    Ready for final controller/inverter setup depending on your preferred configuration
    Collection / Delivery
    Viewing welcome at: G209BT
    Please note:
    This is a very heavy machine
    Just about movable by pallet truck
    Machine height is approx. 2220mm - check height of your doorways
    Weight estimate 2te maybe a little more.
    Delivery options:
    Local delivery available for £200
    Delivery is by trailer only
    No offloading included
    I can also arrange local hiab delivery including lifting to the ground.
    Contact me for a quote for longer-distance delivery
    VAT included in price.
    email [email protected] if interested.
ID:	32886   Click image for larger version.
ID:	32887   Click image for larger version.
ID:	32888   Click image for larger version.
ID:	32889   Click image for larger version.
ID:	32890   Click image for larger version.
ID:	32891   Click image for larger version.
ID:	32892   Click image for larger version.
  2. The Following User Says Thank You to CNCScotland For This Useful Post:
  1. UC300 controller wiring to steppers drivers
    By lateAtNight in forum General Discussion
    Last Post: 09-07-2023, 11:25 AM
  2. 400W motor controller wiring help required
    By RobC in forum General Electronics
    Last Post: 23-11-2019, 10:55 PM
  3. Replies: 7
    Last Post: 05-07-2018, 05:57 PM
  4. Open machine shop in Scotland?
    By gavztheouch in forum General Discussion
    Last Post: 04-04-2014, 10:57 AM
  5. Replies: 0
    Last Post: 06-02-2014, 09:52 PM
