Neither are ideal for high motion use, but if you had to choose take the CY as its better where continuous movement is required due to the stranded conductors. The SY has solid annealed copper, is also thicker (8.5mm v 7mm for 4core 1.0mm2) and has galvanised steel braiding instead of tinned copper braiding.
the 4 x 0.75mm2 is good for up to 8A motorsLast edited by irving2008; 25-09-2010 at 05:25 PM.
25-09-2010 #2
Ok, thanks for that. What cable would you suggest for high motion use, bearing in mind my cable runs are going to have to be quite long.
I was going to get 1.5mm^2 (with 4.2A motors..) since the price difference is not much, and it's nice to keep the voltage drop as low as possible.
26-09-2010 #3
Just worked out that I need about 30m of cable for my router!
The longest cable will be roughly 6m ... is that going to cause a problem? I could save about 8m if I either move the computer, or extend the parallel cable. What's worse extra wire on the parallel or the same on each stepper motor?
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Stepper motor tunning wiring
By handyoodman03 in forum Stepper & Servo MotorsReplies: 47Last Post: 11-01-2013, 05:49 PM -
VFD Cable and 2.2kw spindle wiring
By Flamered in forum Spindles & Drive MotorsReplies: 7Last Post: 24-08-2012, 07:29 PM -
Stepper motor wiring
By Buba b in forum Stepper & Servo MotorsReplies: 5Last Post: 28-03-2010, 06:16 PM -
Stepper Motor Wiring (Screened?)
By pequod in forum Stepper & Servo MotorsReplies: 19Last Post: 03-08-2009, 10:15 AM
