Thread: Recommended DAC please?
Is it worth mentioning that a DAC is a simple resistor ladder, ADC's are the tricky blighters :whistling:
13-09-2011 #2
I've tried making DACs with R2R resistor ladders. They were OK, but not especially accurate due to the way the small errors accumulate. If you buy the resistors in a reasonable quantity then you can spend a bit of time with a meter matching them which can help a lot.
Probably easier just to buy the IC. Something like this:
http://uk.farnell.com/jsp/search/pro...sp?sku=8454647
(There's probably cheaper ones that are adequate - that's just one I've used before so I know it works easily!)
Recommended Cutters / bits from eBay for specific job
By Fivetide in forum Tool & Tooling TechnologyReplies: 1Last Post: 22-11-2012, 11:42 PM -
recommended 3d model software for cnc cutting?
By wyndham in forum General DiscussionReplies: 6Last Post: 01-01-2012, 05:28 PM -
Most recommended plans??
By crazy horse in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 03-07-2009, 02:45 PM
