Thread: ebay board kits v 542 boards
Try this one:
http://www.arceurotrade.co.uk/projects/PSU/index.html
(I notice that diagram has fuses on the secondary side, however I did not include them since each stepper driver already has an internal fuse to protect against over-current. Also any 'nuisance' blowing of that fuse could damage the stepper drivers.)
The colours are not universal, however there is always a clear diagram on the transformer which labels which colour is which.
05-04-2012 #2
05-04-2012 #3
It's on both sides in the diagram on Arc Euro. Stepper drivers can be damaged if the power wires are suddenly unplugged for similar reasons to doing the same to the motor wires. It's less likely but still possible since interrupting the current causes a high dI/dt which will cause a voltage spike.
05-04-2012 #4
05-04-2012 #5
overkill is my theory for future upgrades.. same with the transformer. what would you recomend for overkill..
also i read it as your stepper is rated at x volts. how is the homebrew psu regulated.. to said volts..
eBay TB6560 Stepper Motor Driver Boards
By Mad Professor in forum Motor Drivers & ControllersReplies: 127Last Post: 22-08-2018, 05:32 PM -
Ebay CNC motor kits? Any good?
By gr8fun in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 01-12-2012, 10:58 PM -
By irving2008 in forum Motor Drivers & ControllersReplies: 13Last Post: 07-04-2010, 04:48 PM -
manual for eBay TB6560 Stepper Motor Driver Boards?
By Dan Brown in forum Motor Drivers & ControllersReplies: 5Last Post: 06-01-2010, 10:37 PM -
CNC Kits
By itbookham in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 10-11-2009, 02:56 PM
