06-05-2009 #2
Okay,
Having read through Mach3 site a bit and decided to run the E-stop on the AC side of the PSU and will add a second 2NC switch internal to the E-stop and wire it into the pin 15 point on the BOB.
Now the next problem is I am getting all the LED's lit up but nothing on the board movement. On the DIYCNC BOB the notes don't say whether the jumper needs to be engaged to use the charge pump or not (I believe it does from what I can figure).
I have Three six lead unipolar motors that I have wired in without the centre tap being wired in on advise from a few other CNC operators and they said that it would be okay to wire it that way. Soooooo, as I go slightly
The parallel port is an add on card and uses LPT3 and I/O e800, Soooo.... ....I have been trying to get the card to work porperly and need to know if I should be using port one instead of port two and will give a bit more detail later so those who wish can help as able.
Michael
optoport v3 break out board wiring
By lez allen in forum Motor Drivers & ControllersReplies: 4Last Post: 26-02-2013, 07:38 PM -
Stepper Driver / PSU / Breakout board Wiring ?
By manofgresley in forum General ElectronicsReplies: 2Last Post: 16-08-2012, 05:41 PM -
wiring e-stop button
By deannos in forum General ElectronicsReplies: 10Last Post: 14-01-2012, 11:03 AM -
Additional info System 4 DIYCNC
By m.marino in forum Motor Drivers & ControllersReplies: 6Last Post: 15-02-2011, 02:04 PM -
Nice one Roy at DIYCNC
By routercnc in forum Motor Drivers & ControllersReplies: 9Last Post: 26-10-2010, 02:31 PM
