Thread: dc motor - spindle / shaft drive
DSC
I made a small spindle using a 100w dc motor which was fine for circuit boards. As a suggestion have a look at servo motors instead, tend to have a better torque curve and a lot more controllable? A stepper with a planetary gearbox could work? just rob a drill for its gubbins.
At the speeds you are quoting are you wanting to cut steel?If the nagging gets really bad......Get a bigger shed:naughty:
08-01-2013 #2
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
advise on drive shaft diameters
By bmbaz in forum Machine DiscussionReplies: 2Last Post: 15-05-2014, 10:46 AM -
pulley fit on motor shaft - force it on?
By dsc in forum Belt Drive, Pulleys & TimingReplies: 2Last Post: 09-08-2013, 06:11 AM -
WANTED: stepper motor with dual shaft (6mm dia) wanted
By HankMcSpank in forum Items WantedReplies: 1Last Post: 08-04-2013, 12:48 AM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM
