Just spotted something interesting...
I measured the back-emf voltage from the 3.1Nm stepper motor at 1200rpm and it's 66 volts, so using those numbers k=0.525 Vs/rad. The unit Vs/rad is dimensionally equivalent to Nm/A ... i.e the 'torque constant' of the motor, so we can use this to find the torque for a given phase current. Rated phase current is 4.2A, so for both phases T=2^0.5*4.2*0.525=3.12Nm. That matches the holding torque specification rather nicely, so maybe this could be a simple way to find the rated torque of stepper motors. Or more usefully, use the formula for phase current (something like i(t)=V/R-(V/R-I)*e^(-t/(L/R))) multiply by k to get torque as a function of time then integrate to get the mean torque and then the torque vs speed curve for the motor. I think this should be more accurate than the usual approximation.Last edited by Jonathan; 11-06-2013 at 12:25 PM.
