Gary, does the uim243 have an inhibit/limit input? if not then wont do what OP needs as he wants a parking feature too.
I'd use an Arduino with a stepper driver shield, its quick, cheap and easily adaptable.
Phill05 - pm me if you want some help on this.
06-02-2014 #2
This UIM243 is a very simply and easy to use product.
It is a stepper driver that has a pulse generator built in and can either have an external 0-5V speed reference or use an inbuilt in pot for the speed.
It has an enable and run input.
you can use the run or the enable in conjunction with limits, but a park feature would need a bit more logic behind it.Visit Us: www.automationshop.co.uk
Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
By Mad Professor in forum Spindles & Drive MotorsReplies: 34Last Post: 01-10-2016, 10:21 AM -
800w spindle - noise & controlling remotely
By HankMcSpank in forum Generic Chinese SpindlesReplies: 49Last Post: 17-10-2013, 06:26 PM -
RFQ: Simple job cutting simple shapes out of camera lens cap
By RockandGrohl in forum Projects, Jobs & RequestsReplies: 15Last Post: 20-04-2013, 01:23 AM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
PDA Controlling A Steeper Motor
By ceaser in forum Stepper & Servo MotorsReplies: 5Last Post: 23-05-2009, 03:03 PM
