21-02-2014 #4
I'll swap the motor and hopefully get a properly cut one. The misalignment is pretty severe, so filing it down would be a long process, especially with the keyway being awkward to work on and the material being hardened steel (or whatever the shaft is made of).
Regards,
dsc.
pulley fit on motor shaft - force it on?
By dsc in forum Belt Drive, Pulleys & TimingReplies: 2Last Post: 09-08-2013, 06:11 AM -
16 tooth pulley HTD5 15mm on a 14mm shaft
By dsc in forum Belt Drive, Pulleys & TimingReplies: 6Last Post: 07-06-2013, 11:51 AM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM -
Pulley kit to step up a stepper RPM
By HankMcSpank in forum Belt Drive, Pulleys & TimingReplies: 6Last Post: 11-07-2009, 09:49 PM
