Wal, I've used a microwave motor in the past for a project. they operate on 240v though and are quiet and about 2 quid. Here's one on ebay with 33RPM speed.
AC 220-240V 4W 33RPM CW/CCW Microwave Oven Synchronous Motor | eBay
29-05-2014 #2
29-05-2014 #3
29-05-2014 #4
I did think about that, Clive (you might have suggested it in passing a while back) - was worried that they get pretty hot under continuous use, if I ran it off my control box under a new LinuxCNC profile, it would mean leaving my gear powered up unattended, not too keen on that either - call me paranoid..!
Something will turn up!
Wal.Last edited by Wal; 29-05-2014 at 01:19 PM.
29-05-2014 #5
A microwave motor may work well. If you spin one round and poke your fingers on the terminals you get a reasonable shock, which is quite entertaining.
A cheap (i.e. 2nd hand) drill should also work without requiring much gearing.
Stepper motor are good (ish) when you need to control position, but for spinning things in general you're better off with other motor types as they're a lot more efficient and simpler to drive, so should be cheaper.
Start of a new built.
By Tanky_Turk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 06-03-2014, 09:26 PM -
Mach 3 Driver test results & improvement
By Joe in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 15-12-2013, 11:53 AM -
WANTED: home built cnc
By japcarmaniac in forum Items WantedReplies: 1Last Post: 24-04-2013, 02:35 AM -
MDF CNC Router plans / parts for home build beginners
By HiltonSteve in forum Gantry/Router Machines & BuildingReplies: 81Last Post: 10-06-2012, 02:33 PM
