Thread: CNC newbie electronics query
Skydeals What steppers are you using?
""I havent bought the cy 4 cable yet but i was wondering if all of them come with a wire which is used as ground as well as the 4 wires for driver to motor connection. If so do i connect all the ground wires at the driver end (between driver and motor) to the star point. Am i alright right in the choice of wires chosen and could you advise me on wire between BOB and driver.""
You need 4 core cy cable I use 1mm but some use 1.5mm the screens (braid) of the cy cable are all connected together at the star point at the motor end the cy cable screen is just insulated ( not connected).
I use cat 5 cable between the BOB and driver (twisted pairs) ..CliveLast edited by Clive S; 04-07-2014 at 02:18 PM. Reason: Added text
Query - Zen Toolworks looky likey
By Plod in forum Marketplace DiscussionReplies: 9Last Post: 30-11-2013, 01:15 PM -
Help, electronics
By totts in forum Motor Drivers & ControllersReplies: 2Last Post: 14-09-2011, 09:09 PM -
A simple query about homing switches & milling practise
By HankMcSpank in forum General DiscussionReplies: 5Last Post: 13-06-2009, 11:56 PM -
Monowheel - No electronics
By BillTodd in forum General DiscussionReplies: 0Last Post: 09-06-2009, 09:26 PM
