    Yep it's easy really.!
    Aircooled Cons.
    Aircooled have a Duty cycle so can't run extended periods. How long depends on make and size etc. They are also relatively noisey because they cool using a Fan just like a handheld router does.
    Pro's No external water cooling pipes etc.
    WC Pro's
    Watercooled don't have any duty cycle can run for days at time without any issues. No Fans so very quite.
    Cons's
    Needs water pump and tank for cooling if running long periods.
    Now given your short run requirements and knowing that WC spindles will quite happily run for 30mins or more without any cooling then I'd say go with WC spindle for the quiter running and if you ever do need extended period running then just add a pump and water.!!
    WC spindles don't need much cooling or fancy WC system just a simple submersible pump in sealed Tub of water works great.
  2. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
  3. #2
    Thank you for your reply mate.
    I like the idea of a quiet spindle over a noisy hand held router! I think I may go for a water spindle I heard a quiet one on a youtube video. I just hope it goes OK!
    Suesi
    Aircooled Cons.
    WC Pro's
    Cons's
    Spindles themselves are much quieter than routers and once you have one there is no going back. However the noise of the cutting tool in the workpiece is still quite high and if this still bothers you then you need an enclosure around the whole machine
  5. The Following User Says Thank You to routercnc For This Useful Post:
  6. #4
    Hi routercnc,
    Thank you for your msg. The spindles sound good I think that is how I will go. I don't mind the noise from the cutting tools so I will not need and enclosure.
    Thanks again
    Suesi
  1. Drawing of water cooled spindle
    By GTJim in forum Spindles & Drive Motors
    Last Post: 11-02-2014, 04:21 PM
  2. Do you need to water cool erhm a water cooled spindle?!!
    By HankMcSpank in forum Generic Chinese Spindles
    Last Post: 02-10-2013, 09:59 PM
  3. Replies: 17
    Last Post: 18-09-2013, 06:32 AM
  4. Chinese 2.2 water cooled spindle / Which VFD ?
    By dudz in forum Motor Drivers & Controllers
    Last Post: 16-08-2013, 02:22 PM
  5. water cooled spindle
    By alex wight in forum Generic Chinese Spindles
    Last Post: 21-09-2012, 09:57 PM
