    Quote Originally Posted by Erythros View Post
    I think that separate controller board and inverter with power supply is the only way to go. I recetly began looking into PMSM control and the differences in motors are too big to use one MCU/power stage combo. On eBay there is plentiful of used servomotors from industrial machines (probably from modernization/retrofit), which are quite cheap and for us hobbyist still good enough.
    I tend to agree. Since we're not too concerned about efficiency you can get some way by over-rating the components, which doesn't increase the cost too much, but you soon become limited by the switching frequency (and thus control bandwidth) that can be used.
    I've been vaguely looking out for one to try, as my driver may not be working well with position control just due to the non idealistic properties of the motor I've been testing with.
    Really trying to keep the ball rolling with this project, but my PhD work and related things keep getting in the way as I tend to be spending 9am~8pm in the lab. Still, I have however done some more soldering on a few of the PCBs. Here are a few pictures:
    Can anyone spot the mistake in this one...
    Time to stop now though as it's 1:30am and I don't want to miss the eclipse this morning...
Name:	SAM_2812 (Large).JPG
ID:	14924   Click image for larger version.
Name:	SAM_2814 (Large).JPG
ID:	14925   Click image for larger version.
Name:	SAM_2816 (Large).JPG
    I cant see that great on my phone, but is it that component across the pins on the microcontroller?
    Great work!
    Quote Originally Posted by Gotty101 View Post
    Yes that's right - I accidentally connected the core voltage regulation filter pin to Vss instead of the capacitor. Fortunately that pin is only connected to a capacitor, so I'm instead lifting that pin and soldering an 0402 capacitor between it and the adjacent Vss pin. Bit fiddly, but it works ...
    I've not found any other mistakes yet.
    What Voltage motor would you want I have a few Large-ish Parker AC Servo motors.?
    Sounds good. Anything up to around 300V, 15A would be fine. Do you have the part number so I can check?
    Ok will Dig out and let you know but i think it's much higher than 300v but I may have smaller one kicking around.
    Since joining this site, I have mentioned in a couple of posts that I needed an HF spindle drive inverter (1000hz, not the usual 400hz, and also low voltage - 60volts). I have been trying for several years to get a spare as I knew that my inverter was out of production, and nobody seems able to offer a repair service. I contacted Jonathan who told me that he could configure his new driver to suit my needs, so I ordered two of his new drives. Last week my inverter failed and a quick call to Jon had him burning some midnight oil to finish and set up one of the new drives for me. Thank you Jonathan, I have just installed the new driver and have in fact completed a small job. The spindle runs faultlessly throughout the RPM range and I am very impressed. I am aware that this driver can be configured to perform many more functions than I require, but I am over the moon that I have been able to get an inverter that will drive my spindles. Thanks again jonathan. G.
  1. Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
    By george uk in forum Motor Drivers & Controllers
    Last Post: 23-06-2014, 08:38 PM
  2. Servo drive problems
    By Tomnewry in forum Motor Drivers & Controllers
    Last Post: 27-03-2013, 11:30 PM
  3. servo control vs stepper control
    By Peter. in forum Motor Drivers & Controllers
    Last Post: 17-09-2012, 08:36 AM
  4. NEW MEMBER: I am going to build a 3 axis servo control
    By markey1979 in forum New Member Introductions
    Last Post: 16-11-2011, 12:53 AM
  5. drive control system
    By oadamo in forum General Electronics
    Last Post: 22-05-2011, 07:30 PM
