    I get it, Ethernet isn't suitable for something no-one here needs to do, good point(less) well made!
    I didn't mention TCP/IP and in that I was wrong, I suspect there is very little TCP/IP-Free Ethernet in use outside industrial applications though.
    As for ethernet being unsuitable for rigid tapping and other "closed loop" control processes you are entirely correct and that's why it isn't used for that, but neither is any other remote communication system - the motion controller deals with closed loop rigid tapping locally.
  1. USB/Ethernet controller for Mach3/4 advice
    By paulus.v in forum Control Hardware & Systems
    Last Post: 17-02-2015, 09:37 PM
  2. CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
    By Greeny in forum Control Hardware & Systems
    Last Post: 14-11-2013, 11:59 PM
  3. USB and Ethernet Mach3 motion controller PLCM-E3
    By Purelogic R&D in forum Manufacturer News
    Last Post: 29-12-2012, 09:38 AM
  4. Pros and cons of climb milling in wood
    By Richie in forum Wood Finishing Tips & Tricks
    Last Post: 14-06-2012, 05:09 PM
  5. Types of Ballnut and preload, questions - pros & cons ?
    By Jon S in forum Lead Screws, Nuts & Supports
    Last Post: 16-01-2012, 03:39 PM
