    it depends on your lathe's power. I have machined ends on my little chester using carbide tipped tool
    You do need to take a deep cut starting at the face of the screw. It will glow red and so keep a fire extinguisher handy.
    https://emvioeng.com
    I have not tried to machine ballskrew ends yet but on other hardened stuff I just put it in the lathe and grind the first bit off with a handheld angle grinder while its spinning so you don't get it out of round too far and then machine from there. Depending on how tough the steel on the inside is, you might get away with HSS tooling once you grinded away the chrome and thin case hardened layer.
    This could be the perfect opportunity to build a toolpost grinder for your lathe ;-)
    - Nick
    Quote Originally Posted by komatias View Post
    My lathe is a Chester DB7 - I think the power is probably ok but would be concerned about the rigidity in trying to hog out a hardened ballscrew with a carbide tip. The other problem I see arising is that I have 12x4 ballscrews, which have a root diameter of pretty close to 10mm, and I need to turn them down to 10mm, so I'm never going to get through the hardened section into the soft stuff below, so even carbide turning on a rigid lathe would produce a pretty rough finish
    On reading the previous thread on this subject (http://www.mycncuk.com/threads/2057-...ne-ball-screws), it seems to me that I have two viable alternatives.
    1. get them ground down with a cylindrical grinder (but that still leaves me with having to get a m8 thread onto the end), and would probably cost a fair bit.
    2. drill into the softer core (which I have found that I can do) and shrink fit or loctite an extension which I can them machine to suit
    I'm not too keen on trying the annealing route without knowing what type of steel I'm dealing with, though I may try it on a sacrificial end. One ballscrew I got is about 80 mm longer than I need so if I mess up just the tip I can cut it off and try again
    I'll have a go this evening and see what happens
    Tom,
    I have the same little lathe but have uprated the motor drive electronics. The lathe is good enough for hobby precision ballscrew machining if you use carbide tooling. I have done this.
    The other option is to anneal the portion of the screw you wish to machine. Wrap a wet rag around the portion of the screw you do not want to heat. build a little brazing enclosure out of 4-5 bricks, use a brazing torch or a plumbers torch to heat the end. You need to get it cherry red and let it cool at it's own pace. If you do not keep the screw cool, there is a chance it will warp but this can be rectified later too.
    Again, I have done this with satisfactory results and the screw machines like mild steel.
    Tom,
    Interesting on the DB7 electronics upgrade - I'd like to find out a little more about what you've done - but maybe offline. I fitted a cooling fan behind the motor and it can run at fairly low speeds without overheating, so it's at least better than the factory standard.
    As to the ballscrew, I will try the annealing trick. I have about 3 inches to play with so even if it goes wrong I can just cut off the bad bit and start again..
    As a matter of interest, after annealing, did you cut with carbide or would HSS do ? Reason I ask is that I don't have any carbide tools, but have lots of HSS available.
    I used carbide tooling. When it is properly annealed however you can file the section you heated, so I imagine HSS should be fine.
    IT is a good investment to buy some indexable insert tools and a good toolpost for the DB7.
    I swapped the motor drive out for a Parker SSD DC drive after the original motor controller blew up literally. It give very good torque at low RPM and is fully adjustable.
    I'm happy to say that after annealing the end of the ballscrew, I was able to cut it with little difficulty with a sharp HSS tool (see photo). Taking a 12mm ballscrew down to 10mm doesn't quite reach the bottom of the thread, but it'll still be fine to fit a bearing. Thanks for allthe good advice.
    Now my next challenge is to find somebody near me (West Sussex) with a mill who would be able to help machine the cross-slide of my mill to fit the ball nuts.
  1. Advice on new table and ball screw.
    Last Post: 26-07-2012, 10:45 PM
  2. Ball screw
    By luke11cnc in forum Lead Screws, Nuts & Supports
    Last Post: 20-10-2011, 01:28 PM
  3. WANTED: 12mm ball screw & nut
    By phill05 in forum Items Wanted
    Last Post: 22-06-2010, 09:26 PM
  4. Ball Screw Accuracy V Price
    By Wobblybootie in forum Lead Screws, Nuts & Supports
    Last Post: 02-01-2010, 11:55 AM
  5. Stationary Ball Screw
    Last Post: 29-12-2009, 01:12 PM
