Page 1 of 3 123 LastLast
    Hello,
    I need help with generating a part to an STL file. I had a colleague of mine generate it but it was not curved, but instead angled. We are using DeskCNC (Carkin) to run our CNC XYZ router table, but that's a whole another issue. It will accept DXF or STL files, but since this is a 3D part, I was told that STL might be a bit better.
    This is generally what we want to machine:
    However, the part we are trying to machine is a block that is 4" x 4" x 1/2" thick with a cylindrical shape cut out of it so it appears similar to this:
    Again, it is not 8" x 2", it is 4" x 4". The radius required is 5 17/32".
    So basically it's a block minus the cylindrical portion removed. I have tried several different CAD programs including FreeCAD, but could not getit to work. Call me a CAD dummy.
    I am attaching what I came up with for the STL file and resulting G-code (NC code).
    However, when I run this on our setup, the axes stall through DeskCNC. Maybe the
    rapid moves are stalling the motors? We have been able to cut simple parts with the
    same config, but then again this is a different type of G-Code file.
    Any hints or help are very appreciated.
    Mike
    Attached Files Attached Files
    Hello
    What cutting tools do you have and whats the material?
    I made this gcode for you, it's assuming you have a ball nosed end mill and you have already roughed it out(taken away the bulk of the waste). You need to edit the lines for the spindle speed if applicable(M03) and feedrate (G1 Z0.5 F11) for your machine. Also I assumed a 0.1 width of cut which maybe wrong for your cutter.
    Code:
    G20 G18
    M03
    G0 X0 Y-0.2 Z2
    G1 Z0.5 F11
    G3 X4 R5.53125
    G1 Y-0.1
    G2 X0 R5.53125
    G1 Y0
    G3 X4 R5.53125
    G1 Y0.1
    G2 X0 R5.53125
    G1 Y0.2
    G3 X4 R5.53125
    G1 Y0.3
    G2 X0 R5.53125
    G1 Y0.4
    G3 X4 R5.53125
    G1 Y0.5
    G2 X0 R5.53125
    G1 Y0.6
    G3 X4 R5.53125
    G1 Y0.7
    G2 X0 R5.53125
    G1 Y0.8
    G3 X4 R5.53125
    G1 Y0.9
    G2 X0 R5.53125
    G1 Y1
    G3 X4 R5.53125
    G1 Y1.1
    G2 X0 R5.53125
    G1 Y1.2
    G3 X4 R5.53125
    G1 Y1.3
    G2 X0 R5.53125
    G1 Y1.4
    G3 X4 R5.53125
    G1 Y1.5
    G2 X0 R5.53125
    G1 Y1.6
    G3 X4 R5.53125
    G1 Y1.7
    G2 X0 R5.53125
    G1 Y1.8
    G3 X4 R5.53125
    G1 Y1.9
    G2 X0 R5.53125
    G1 Y2
    G3 X4 R5.53125
    G1 Y2.1
    G2 X0 R5.53125
    G1 Y2.2
    G3 X4 R5.53125
    G1 Y2.3
    G2 X0 R5.53125
    G1 Y2.4
    G3 X4 R5.53125
    G1 Y2.5
    G2 X0 R5.53125
    G1 Y2.6
    G3 X4 R5.53125
    G1 Y2.7
    G2 X0 R5.53125
    G1 Y2.8
    G3 X4 R5.53125
    G1 Y2.9
    G2 X0 R5.53125
    G1 Y3
    G3 X4 R5.53125
    G1 Y3.1
    G2 X0 R5.53125
    G1 Y3.2
    G3 X4 R5.53125
    G1 Y3.3
    G2 X0 R5.53125
    G1 Y3.4
    G3 X4 R5.53125
    G1 Y3.5
    G2 X0 R5.53125
    G1 Y3.6
    G3 X4 R5.53125
    G1 Y3.7
    G2 X0 R5.53125
    G1 Y3.8
    G3 X4 R5.53125
    G1 Y3.9
    G2 X0 R5.53125
    G1 Y4
    G3 X4 R5.53125
    G1 Y4.1
    G2 X0 R5.53125
    G0 Z2
    M30
    So what do you want STL file or G-code file.?
    For G-code we will need more details like Cutter type and diameter, # of flutes, Material.
    Rufe0 he needs it concaved your code is convexed.
    There you go 4x4 saved as a STL let me know
    Also, by programming a ball-nose tool to trace an arc, it will not cut the same path, unless the tool radius is zero! This is due to the way the contact point on the tool moves - my quick diagram should make it obvious:
    Try it Old school and learn G-code from Master TP (terry parker).!!! https://www.machsupport.com/forum/in...?topic=24988.0
    RE: JAZZCNC
    It looks pretty concave to me, I guess if you had your machine set with the Z low at the top and high at the bottom then it would be, anyway it's a simple task to do file>replace the G2>G3 and vise versa.
    RE: Jonathan
    Yes I forgot to mention he would need a ball nose tool with radius less than 5 17/32.
    You could do it longitudinally with a normal endmill but you'd be massively wearing the tooth corners out and it would take practically a million passes to get smooth.
    The ideal way todo this would be with a fly cutter however you'd need a horizontal mill, unless you could fix the work piece vertically.
    Quote Originally Posted by Rufe0 View Post
    RE: Jonathan
    or equal to! But more seriously, that's not the point I was making - your code will be more accurate as the tool diameter tends to zero, so clearly you need to compensate the tool height as in my diagram.
    I'm not sure that the code Jazz has linked to does this either?
  1. RFQ: Small aluminum milling/water cutting
    By Harry Hills in forum Projects, Jobs & Requests
    Last Post: 02-11-2014, 01:54 AM
  2. NEW MEMBER: where to buy aluminum extrusion
    By troyboy1 in forum New Member Introductions
    Last Post: 21-07-2014, 01:52 PM
  3. symmetrical hart shape in vectric v carve pro
    By cockneyrebel in forum Vectric
    Last Post: 24-02-2014, 02:55 PM
  4. Flexible Stainless Steel pipe that holds its shape?
    By Fivetide in forum Marketplace Discussion
    Last Post: 14-02-2013, 07:35 PM
  5. tool for aluminum on uk
    By edgas10 in forum Tool & Tooling Technology
    Last Post: 26-04-2011, 11:23 AM
