    Hello all
    I am needing a little advise please! I don't know about thread milling. What I am wanting is some blind holes in 316 thread milling to take a m12 thread. Could a 6mm deep hole be thread milled or is that just silly and totally impractical? The thread are just going to be little blanking caps just held on with a bit locktite.
    Cheers now
    Steve
    Hi Steve
    No logical reason why you can't do it, hole will have to be flat bottom then i would undercut to slightly over thread dia with tool just clear of bottom of hole then run your thread.
    Regards
    Mike
  3. The Following User Says Thank You to mekanik For This Useful Post:
    Hi mekanik
    I appreciate you taking the time to reply. It is great that can be done, I am a happy! Had it not have been feasible I would have been in for a pig of job.
    Many thanks
    Regards
    Steve
  5. #4
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by suesi34e View Post
    Hello all
    Cheers now
    Steve
    Could you not just epoxy the caps in? or do they need to be removed?
  7. #5
    You could also use a roll tap, just interpolate a flat bottom hole first then tap to depth. A roll tap would be cheaper than a thread milling cutter.
  8. #6
    Quote Originally Posted by jamesgates1000 View Post
    Woukd nit fancy my chances of forming M12s in 316, the bugger galls to easily
    Be sure to get a threadmill that is big enough to cut the pitch you need. Bought a 6mm one the other day, can only do up to 1mm pitch....
    A larger threadmill will do smaller pitches though may not be able to get into small holes
    https://emvioeng.com
  9. The Following User Says Thank You to komatias For This Useful Post:
  10. #7
    I've been looking into threadmills as it sounds like good sport ....anyone got a good source for them?
    Neil...
    Build log...here
  11. #8
    Hi Steve
    You would be as well doing some test pieces first, as stated Stainless is a bugger.
    What's the application ?
    Regards
    Mike
  12. #9
    Got mine at drill services.
  13. #10
    Hi Neil,
    I am not sure so don't quote me on it but I think I got my ones from J&L. I notice you mention thread mills and good sport I notice you don't mention 316 in the same sentence!
    I was watching one of your videos earlier in the inspiration thread you build looked to work out a treat for you.
    Steve
  1. solidoworks tapped thread depth and blind hole depth
    By reefy86 in forum CAD & CAM Software
    Last Post: 10-11-2015, 04:14 PM
  2. Tips and tricks for shallow milling/ engraving ?
    By Gasgasbones in forum General Discussion
    Last Post: 11-01-2015, 09:39 PM
  3. Hole Radius
    By benkat in forum Machine Discussion
    Last Post: 03-03-2014, 05:29 PM
  4. SBR16UU Centre hole.
    By cambesol in forum Rails, Guideways & Bearings
    Last Post: 25-11-2013, 05:39 PM
  5. 6mm shaft to 6.35mm hole?
    By JuKu in forum Metalwork Discussion
    Last Post: 15-12-2012, 02:29 PM
