Thread: Comparing motion controllers...
1 – Can’t stop thinking if it would be possible to install a second switch anyway? Or is that what you just said?
Connected so that the signal that keeps the gantry moving continues until both switches have broken the circuit.
It’s not the proper way to think but I’m new to this and I guess if it would be that simple, it would have been done right?
2 – To install 2 reference “pieces” from where the gantry position on each side can be measured.
So once in a while after homing the gantry I can twist one of the screws manually to set the gantry square and then turn it on again.
Would that work?
3 – I could let both ballscrews be driven from the same motor but I guess that would require a belt and with that I would loose some of the precision.
4 – What is the downside of squaring it the crude way besides that it feels… Crude?
5 – Would it help a bit if I choose 400 step motors instead of 200?
11-02-2016 #2This is one of the standard ways of doing this and has been proved to work well. If you look through the forum there are many cases where it has been done this way.3 – I could let both ballscrews be driven from the same motor but I guess that would require a belt and with that I would loose some of the precision.
Installing a second switch as your point (1) will not work. Point (2) Will work as Jazzcnc has already said (but it is not an elegant way of doing it). Not sure what you mean in point (5) it has nothing to do with the homing sequence..Clive
11-02-2016 #3
To answer your last point,
When you set up your stepper drives system, you should set the drivers to microstep. That will make them run smoother and also allow you to have better resolution of angle. 10-16 microsteps is good depending on what resolutions you really want.https://emvioeng.com
11-02-2016 #4
When i looked at stepper motors i found motors with different step angles.
0.9° - 400 steps/revolution
1,8° - 200 steps/revolution
Im thinking that if i choose the one with the higher resolution Everything will be better...?
Allthough ive got a feeling its not that simple...
11-02-2016 #5
11-02-2016 #6
11-02-2016 #7
Hear you... Ive just read about microstepping and torque and so on. It seems like the real benefit of microstepping is not so much improved accuracy as less noise and less wear as mentioned above... So, i will settle for the more common 1.8°motors and i will set the drivers to microstep.
11-02-2016 #8
11-02-2016 #9
11-02-2016 #10
I use a belt and a single stepper and an IP-M and I'd say that I'm not losing any precision! I cut plastic bearings for work and easily hold tolerances down to 0.1mm (although plastic does creep after machining) and I'm sure if I cut some aluminium or suchlike I could hold better tolerances...in short what I'm saying is that a belt will not lose you precision but will mean that you can't rack your gantry and only need one homing switch not two....lots of pros and can't see too many cons (apart from having a long belt running at the back of my router.)
The Following User Says Thank You to njhussey For This Useful Post:
Wiring Steppers to controllers
By liamo1991 in forum Motor Drivers & ControllersReplies: 1Last Post: 05-09-2013, 01:58 AM -
PCI Motion Controllers
By IanS1 in forum Motor Drivers & ControllersReplies: 0Last Post: 16-05-2013, 12:13 AM -
Difference between controllers and Cad/Cam programming???
By 0625272 in forum Computer SoftwareReplies: 0Last Post: 23-06-2011, 08:40 PM -
Programmable logic controllers
By cncezee in forum Motor Drivers & ControllersReplies: 12Last Post: 15-11-2010, 08:44 PM -
FOR SALE: DC Motor controllers - 24v and 36v up to 160A
By HiltonSteve in forum Items For SaleReplies: 10Last Post: 02-06-2009, 10:36 PM
Low-inductance, bi-polar... Theres a lot more to that but im getting there...
