Im not sure if you have an R S Components or similar electronics store where you are to buy a pot.
What I used is a 10 K Ohm 10 turn linear pot rated at 1 Watt. The 10 turn pot is better for finer control when you want to set up a specific speed. If you don have an electronics store around then you could try ebay but go for a decent make like Vishay. The connections for it will be in your manual for the vfd. You may also have to alter one of the parameters to tell the vfd where it is getting its speed control from such as the external pot. The manual should explain this but you may have to do a bit of digging to find it. Sometimes the manuals don't always explain everything clearly but any more question just ask.
17-02-2016 #2
22-02-2016 #3
Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
By Mad Professor in forum Spindles & Drive MotorsReplies: 34Last Post: 01-10-2016, 10:21 AM -
Help needed connecting IMO JAGUAR VFD to Orac
By asto in forum Spindles & Drive MotorsReplies: 0Last Post: 09-04-2013, 08:05 PM -
huanyang vfd 2.2 error E.CO.A
By edgas10 in forum General ElectronicsReplies: 0Last Post: 01-07-2012, 08:12 PM -
connecting stepper driver to PC
By berkut in forum General ElectronicsReplies: 2Last Post: 10-06-2009, 09:25 PM
