Thread: Limits, homes, override switch
Your inputs have common ground. You can use only PNP sensors. You may use 24V if you wire the input through a resistor of a calculated value. There is no info of the inputs voltage in the manual, but you could find out by reading the resistor values and/or optocoupler model.
26-02-2016 #2
I think all the inputs are 5V. How would I wire the resistor (I mean, I know it's a simple wiring diagram), but how do you actually wire it. Is there any kind of "terminal resistor" ?
26-02-2016 #3
I saw only once a special resistor socket to be inserted in terminal block. And there are terminal blocks with resistors, diodes, electronics fitted inside.
The simple way is to solder the resistor to the wire end. The third method is not recommended unless you solder the input wires together.
19-10-2016 #4
The LJ12A3-4-Z/BX sensors I use with this board are NPN - the output of the sensor goes to GND when triggered - which is what you want. The board has pull-up resistors so that the untriggered state is strapped to 5v. You don't need resistors as the 24v power to the sensor is limited in current to 2.4mA and in voltage by an internal zener diode in the switching circuit.
These sensors have been designed to make connection simple and to have wide application, why do people then have to make things complicated. If you complicate you introduce the possibility of design faults and unreliability.
I lose the will to live every time someone mentions a relay in a homes circuit.
For Pete's sake, there is plenty of info and advice on t'Interweb. Do a bit of searching online before you regurgitate the same old questions.
Happy bloody christmas !!!!
Rob
feedrate override using rotary momentary switch?
By routercnc in forum General ElectronicsReplies: 8Last Post: 26-02-2015, 10:11 PM -
Proximity switch NPN or PNP
By Matt81 in forum General ElectronicsReplies: 9Last Post: 19-04-2014, 11:38 AM -
stepper acceleration rate - limits?
By dsc in forum Stepper & Servo MotorsReplies: 11Last Post: 02-03-2014, 02:25 PM -
limits on mill table
By John11668 in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 31-08-2011, 06:46 PM -
Limits or homing switchs???
By Ross77 in forum Computer SoftwareReplies: 11Last Post: 28-03-2010, 03:17 AM
