27-11-2016 #5
That is only a 24V/5A so it will not work, at least not with any significant torque, if at all. You get 10A out only if you flip the switch to 12V out.
No, you will probably not die if you connect it, but of course, no guarantee is given by me. Anyway, why would you buy that to run motors? I mean, as far as I know, lead battery chargers pulse the output, which means that you need to modify the charger to get constant voltage and current out of it, and based on your questions, you can't do that. Why not buy a proper power supply? OK, more expensive... but there is a reason.
About to take the plunge - quick power question 3020 CNC
By Sherpa in forum Chinese MachinesReplies: 5Last Post: 23-09-2016, 10:41 PM -
Just starting out - quick question
By glynster in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 06-02-2015, 06:20 PM -
quick question about lead screw
By japcarmaniac in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 09-02-2013, 11:25 PM -
Quick cable question
By PWD in forum General ElectronicsReplies: 18Last Post: 11-12-2012, 09:25 PM -
Quick question
By m.marino in forum General DiscussionReplies: 2Last Post: 18-02-2011, 04:30 PM
