Thread: Earthing?
    Did you fit the optional braking resistors?
    Robin would you please explain how to fix a braking resistor to the motor in this case
    Robin would you please explaining how to fix a braking resistor to the motor in this case
    You can fit a braking resistor if the driver black box has provision for a braking resistor. A braking resistor dissipates unwanted energy and is one of the reasons a body might chose thicker wiring.
    Exactly Clives point I think.!!! . . . There isn't a blood option for braking resistor on AM882 and tell the last time you or anyone else seen Nema 23 3Nm stepper motor fitted to Minimill using braking resisitor.!! . . . . . STOP TALKING SHIT.
    Hahaha, this is getting interesting:)
    In the EM806 and AM882 don't you have an over-current cut off with the red LED blinking? I think you really have to push them really hard, for instance, with high deceleration to get to that stage. I don't intend to drive this machine too madly:)
    Also, I guess the psu will be able to cope with a bit of back EMF if I feel too adventurous...
    Edward
    Robin Can you please send me some of that shit you are on as it just might help me to understand what the f@*k you a taking about.
    I keep taking breaks from PCB design. I am trying to wire up a 168MHz processor without resort to 4 board layers and it is not easy getting sufficient decoupling and copper down to get the power everywhere it needs to be. I am having real problems while you lot are having imaginary problems and I guess I am getting a bit jealous.
    To quote Jesus, purely because it is hard to argue with Jesus, "You're far too keen on where and how, but not so hot on why"
    Can you point me to the document where HE wrote that please.
    You don't believe me? Google is your friend
    I wonder WHY all the time.? . . . Often wonder WTF your on about and WHY you say the Shite you do.!! . . . . . Go back to the Stone age because your just confusing new users with BUM info that isn't relative to todays modern components.!! . . . . . Sorry to be so harsh but your going to cost somebody lot of wasted time and possibly money with such Rubbish.
    Now that's the last I'm saying so OP can get back on track.
    Edward:
    You won't get near taxing those drives with Mill this size so don't worry about Over current etc. Just fit and enjoy.!
    Regards Earthing then just use Star ground and shielded cable and you won't have any troubles. Size wise then 1mm is fine for motors and limits etc so just buy one size as it's easier and often cheaper as Some suppliers have minimum qty. 4-Core will do both
    Brilliant, thanks Dean and everybody, I'll just get on with it.
    I think this thread is quite old, but the OP asked questions that I was also interested in.
    Edward
  1. Laser Machine Grounding/Earthing
    By Want2build1 in forum Laser Machines & Building
    Last Post: 09-02-2015, 10:18 PM
