    Hi Chaz,
    This is not what you want to hear but I only spot drill on steel, then over to the drill press to finish off. Chinese spindle is way to fast to use as-is, and when slowed down the torque is too low, as you say.
    Or I use the methods above and interpolate with an end mill with plenty of oil. You can certainly hear and feel that it is cutting something tougher than aluminium (on my modest router machine anyway).
    For aluminium I pilot drill using a 3mm twist drill at 10,000 rpm and peck to the required depth (occasional dab of lubrication). Then over to the drill press or cordless drill to the final size.
    On my new machine under construction I have allowed scope to fit an indirect drive WC spindle through a multi-V pulley gearbox to get the speed down (and torque up).
    Tell me more about the WC spindle please.
    Might have got you excited over nothing. WC just means water cooled Chinese spindle
    See my signature mk 4 build post 86 for where I was making sure design would allow for geared spindle drive
    Thanks, noted, checking.
    Just read through the thread quickly. I can see the spindle body, lovely. Are you able / willing to share the design please? This is to use R8 / TTS?
    To be clear I'm not planning to build this any time soon. When the new machine is finished I'll run with the spindle direct and see how it goes. Significant stiffness increase should allow me to do much more than current machine.
    But the indirect drive version of the spindle does indeed use the R8/TTS combo with tools changed manually via the draw bar. But I basically threw this together to make sure when the time comes I had space to do the upgrade. Not worked out pulley reduction and the speeds I might want or gone deeply into bearing size and max rpm or looked at any optimisation of parts.
    I'll see if I can output a few of the key parts (bearings housing spindle drawbar) to give you a start point if you are ok with it on that basis. I don't know if this will work but has the right features. You need to think about hardening and grinding of the taper and possibly bearing journals unless you want to make a demo part first
    I can do iges format which most cad programmes can read. Away from machine so give me a day or so.
    If you use it and develop and build something please post it up as you'll probably get there before me ! Thanks
    Ps with a bit of work a PDB can be added to give quick changes. I won't go this far but ATC is then possible if you want to add that as well
    Thanks, anything appreciated. I can open all formats with Fusion 360, so happy to look at the design. Might be worth doing something together? Im tempted to get something working that can be used by many.
    I see at least some one is making lower RPM spindle in the standard 80mm mounts compatible with standard VFD's
    https://www.youtube.com/watch?v=T-F_xZHEWDU
    I'm surprised the Chinese aren't already all over it.
    I cant see how its done. Some form of gearbox on the front of the spindle?
    I can hear why they've disabled comments for the video ;-)
    It's made in China, just like every other round spindle.
    If you download the "manual", it's only 6.4 amps, so it's power is actually less than most 1.5Kw spindles.
    Just another company self-proclaiming to be CNC experts.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  1. RFQ: Large bed CNC Mild Steel (500 x 500 x 50)
    By Jono in forum Projects, Jobs & Requests
    Last Post: 03-04-2017, 05:05 PM
  2. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  3. Replies: 0
    Last Post: 16-06-2013, 01:33 PM
  4. High speed spindle for Sieg X1
    By ecat in forum Spindles & Drive Motors
    Last Post: 29-03-2012, 08:56 AM
  5. High speed spindle
    By leadinglights in forum Tool & Tooling Technology
    Last Post: 27-04-2010, 09:23 PM
