Quote Originally Posted by eci22 View Post
Do you mean like this ?
Not really, I'm pretty sure it would be best to have the Hiwin rails fix directly onto the plate (which will add some rigidity already, especially with the extra stiffness of steel, so would be worth adding into you simulation) I was meaning maybe either side of the ballscrew (assuming there's enough clearance) or even on the front either side of the spindle mount if there's space. Just trying to help you add some cheap rigidity :-)
The FEA software is Fusion 360, it is really nice once you get used to it. What kind of ballpark figures should I be looking at for in the deflection analysis ? At the moment I'm not actually taking figures as real world numbers, but more to compare the deltas between different designs.
I'm no expert on dynamic loads whilst cutting, but as it's not exactly a smooth process (hence the noise!) I would expect peak loads to be may 1.5...2x the static???
