Thread: Mill with digital scales
Sounds interesting... so lets see some pics :)
Thanks, I'll go investigate
Yes I know. Go to do a back-emf dumper and some sort of voltage limiter (not a regulator as such) - looking at some ideas that combine the two. Don't want to use a series regulator cos of the losses involved at 6A+ (if all 3 axis active) but thinking along lines of series/shunt MOSFETS (got a couple of samples rated at 120A, 200V and 0.003ohm Rds, so even at 10A its not going to get warm if turned fully on!)
19-08-2008 #2
19-08-2008 #3
20-08-2008 #4
21-08-2008 #5
Robin,
Have you seen this thread on CNCZone discussing PIC-based DRO capbility using cheap chinese scales?
regards,
Irving...
21-08-2008 #6
I guess, seeing as you posted there tonight, the answer is now yes :)
21-08-2008 #7
Absolutely, thanks for the heads up :D
I'm not sure he isn't introducing too many delays, that scale data gets very stale very quickly. I suppose it all depends on what he is trying to achieve.
I made the data input, scale reading and motor stepping completely interrupt driven. There is a sort of housekeeping program that looks for new devices and button presses, but all the vital stuff happens automatically in the background without the slightest intervention apart from Pause and Abort. It's as close to real time as I can possibly make it. I find PC's are a bit too handy at turning the interupts off.
22-08-2008 #8
Using a PC for anything truly real-time is hard - actually its not the PC of course, but Windows that is the issue. There are good real-time extensions for Linux and there used to be a pretty good real-time extension for Windows too but I don't know what happened to it - http://www.directinsight.co.uk/produ...urcom/rtx.html is something similar though. I've done projects in the past with single board and single chip solutions with tiny real-time kernels such as iRMX, embedded Linux as well as solutions based on WindowsCE, stuff you couldn't begin to make work reliably under Windows.
Digital angle gauge
By njhussey in forum Tool & Tooling TechnologyReplies: 4Last Post: 04-12-2012, 08:07 PM -
FOR SALE: DRO + 4 Scales
By Rikk in forum Items For SaleReplies: 0Last Post: 22-10-2011, 09:41 AM -
Digital drivers from Zap
By Simon C in forum Motor Drivers & ControllersReplies: 5Last Post: 31-03-2011, 03:27 PM -
FOR SALE: digital vernier.
By i2i in forum Items For SaleReplies: 8Last Post: 13-08-2010, 11:31 AM -
Reading and fixing Chinese scales
By irving2008 in forum Tool & Tooling TechnologyReplies: 26Last Post: 24-02-2010, 10:35 PM
