    If you was building a plasma machine I'd say that's perfect. But if you want a serious router then it needs lot more work.
    The Bottom Pic looks very much like Merchant Dice machine and just ask anyone about how well MD machine performs..
    Your gantry design is week and far too weedy for decent router this size.
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  3. #2
    the gantry looks a bit too low to me, id say try to get this a rock solid as possible, I thought machine was solid but turns out the ready made z axis assembly is not solid enough, getting vibration when cutting 18mm mdf in one pass, It the only bit that hasn't got hiwin rails, will changing it soon and ill be changing my spindle for an ATC spindle
    Quote Originally Posted by malcolm01 View Post
    Ah sorry to hear that, but thanks for letting me know. I was considering just buying theirs. I tried to keep the gantry as low to the rail as possible. Droping the bed lower instead of raising the gantry seems like it'd be stronger.
    I need to go see my engineer now I have a little more idea about what I want. Doesn't seem too difficult to make the z axis from scratch.
    Sent from my SM-G935F using Tapatalk
  5. #4
    the guy jazzcnc sent a link to an American site that looked good, they have a preassembled part that I really like the look of
    https://www.aliexpress.com/item/CNC-...6ab831b0ZkP59s
  6. #5
    Wouldn't buy that either.? Those ball screw bearing blocks are not designed for this purpose and will almost certainly have some end float.
    Also the price is ridiculous. You can buy all the bits and build your own better for lot less.
  7. #6
    Looks a lot like my Z axis but I have BK12/BF12 fittings
    Cost me ~£100 to build but I recovered the Hiwin's.
  8. The Following User Says Thank You to Desertboy For This Useful Post:
  9. #7
    Yeah that's nice and simple looking, is it meaty enough Desertboy for your uses?
  10. #8
    if you look at my c beam picture, I joined 3 bits of aluminium together, this is ridiculously rigid but very heavy! if I could do this again id use light weight aluminium profile instead! I have no doubt it would be still as rigid, keeping the weight down would be a good idea because the gantry is cumbersome and requires a lot of power to heave it about, the x axis struggles while the y axis flies
    I'm not so sure keeping it so low wouldn't ending up causing you problems down the line. also when I'm making a new base for my machine I plan to make the underside suitable for sheet storage, my workshop is small and the machine swamps the place so sheets lying around are a real pain
  11. #9
    if you look at my c beam picture, I joined 3 bits of aluminium together, this is ridiculously rigid but very heavy! if I could do this again id use light weight aluminium profile instead! I have no doubt it would be still as rigid, I'm not so sure keeping it so low wouldn't ending up causing you problems down the line. also when I'm making a new base for my machine I plan to make the underside suitable for sheet storage, my workshop is small and the machine swamps the place so sheets lying around are a real pain
    Yeah I spent a little while trying to find one like it until I looked at the picture more closely! Nice idea about storage ... is the base of yours made from wood?
  12. #10
    Quote Originally Posted by HullMark View Post
    I think I'll maybe go with your c beam then, it's an option for sure
  2. BUILD LOG: New Build Log ... 2440 X 1220 X 300
    By Wobblybootie in forum DIY Router Build Logs
    Last Post: 17-10-2014, 11:20 AM
  3. Replies: 1
    Last Post: 01-03-2014, 01:31 AM
  4. BUILD LOG: Steel Router 610 x 1220 x 200
    By Stickio in forum DIY Router Build Logs
    Last Post: 18-08-2011, 07:27 PM
