  1. #9
    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    t was more hassle getting a pc to actually work with the pci card I got.
    If you are talking about the 7i25 card. Then I have to say that I have used a few of these with no issue. I have also had a lot of success with using PP pci cards with Lcnc with much issue.
    You are correct that if two motors need to be homed to set the gantry square each time, then at this time you have to use the dev. branch (2.8) to do this. If that is not required then the best version is 2.7.12
  1. Recommend me an ATC Spindle
    By andy_con in forum Milling Machines, Builds & Conversions
    Last Post: 26-07-2016, 10:40 PM
  2. Recommend me a Laser cutter.
    By Gasgasbones in forum Laser Machines & Building
    Last Post: 07-06-2015, 04:45 PM
  3. EXPERIENCE: Would recommend - CNC Company in Notts.
    By TonyD in forum Trading Experience & Feedback
    Last Post: 15-04-2013, 08:06 PM
  4. Which kit would you recommend?
    By ian823478 in forum Motor Drivers & Controllers
    Last Post: 08-04-2012, 11:05 PM
  5. Please Recommend me a CNC mill for....
    By Gasgasbones in forum General Discussion
    Last Post: 29-11-2010, 07:17 PM
