Thread: PWM control for single AC motor?
If going the Arduino route you're better off with grbl and a uno/cncshield combo, they're super cheap I paid <£10 for mine on ebay from UK seller.
https://blog.protoneer.co.nz/grbls-p...speed-spindle/
You could also use a variac to control the speed.
Good luck with your build.Last edited by Desertboy; 07-04-2018 at 10:51 AM.
07-04-2018 #2
I've actually already got one of those for about £4. It seems very... lacking. With the RAMPS1.4 I can add LCD and SD control, better processing and a tonne more peripheral pins if I need them. As Marlin is based on grbl it holds a lot of the functionality and holds a CNC configuration option anyway. So overall it looks like the better option.
Yes, a variac, but see, I'm trying to control the speed automatically. If I wanted to manually control it I'd just move the existing control box to a remote location. I've since solved this issue (run motor as DC via bridge rectifier).
Nevertheless, thanks and thanks again for the good wishes, I'm sure I'll come across a few issues along the way :)
WANTED: 2.2 KW 3 Phase Induction Motor
By Chaz in forum Items WantedReplies: 5Last Post: 23-11-2017, 06:18 PM -
Hi looking to change 3 phase motor for a 240v, any help much appreciated
By suesi34e in forum Workshop & EquipmentReplies: 21Last Post: 19-01-2017, 01:49 PM -
formula for capacitor on 3 phase motor
By dudz in forum General ElectronicsReplies: 10Last Post: 13-11-2015, 05:37 PM -
Myford 7, 3 phase motor other CNC questions.
By Jconway651 in forum Lathes, Lathe Rebuilding & ConversionsReplies: 23Last Post: 28-01-2015, 10:33 AM -
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM
