Page 1 of 3 123 LastLast
    Quote Originally Posted by driftspin View Post
    After switching off primary power supply the drives drain the caps quickly. Even with no steppers attatched.
    You can check it only takes 10 seconds or so.
    Please check your setup with a dvm
    Grts Bert.
    Hi Bert
    Do you think it's not worth bothering with the bleed resistor ?
    cheers
    Andrew
    Lives in Plymouth, United Kingdom. Last Activity: 20 Hours Ago Has a total post count of 1,747. Received thanks 298 times, giving thanks to others 11 times.
    One of the crazy things about specifying a bleed resistor is that it is based on things like heat dissipation at the time it is not doing anything useful, just sitting there wasting energy. The amount of stored energy that it actually needs to bleed if the input voltage fails or is switched off is very small. I chose to forget it altogether - I didn't want all that extra heat and wasted energy when, in practice, the drivers do the job very effectively. The only time a bleed resistor would be useful is under unusual conditions, during testing, for example. I'm happy to be aware of the issue at such times - it's no worse than avoiding the mains connections, for example. I'm not criticising people who do fit them, but for me it falls into the same category as a "cabinet open" switch. Commercially you should fit one of these in case some clown opens the cabinet and puts a finger where they shouldn't. For home workshop use, I want to be able to run with the door open sometimes - for example, to measure the power supply voltage to see what happens when it is turned off!
    I have three e-stop switches around the machine and limit switches on all axes (except lowest position, of course). For me, that is a reasonable set of safety features; there's an MCB where the power enters the cabinet, a safety relay, and a fuse on the motor PSU (because it was fitted when I bought it). The only failure I have had on my machine was that fuse failing - through age, it seems, as there was no overload. Other people fit MCBs, fuses, etc, all over the place. Opinions vary!
    Quote Originally Posted by the great waldo View Post
    Bleed resistors are pointless, unless you have a very high voltage and you must work with the equipment, for example a camera flash, which is potentially dangerous unless you drain the capacitor, or measure the voltage and KNOW that the capacitor is discharged, which can take a very long time in case of a flash. In normal power supplies it will be drained after maximum a few minutes, even without any bleed resistor because you most certainly have some things, like a driver, or other electronics connected to it. Bleed resistors are just waste of energy when the PSU is ON. In your case, 50VDC isn't a risk anyway, unless you are easily scared. You may feel it, but nothing more. Besides, it can't be charged to more than 50V anyway. The fact that you are using 100V capacitors says nothing about the stored voltage, only that the capacitors can be used up to 100V. Your capacitors will never be charged over 50V if the PSU is 50VDC out after the rectifiers.
    What I think is MUCH more important is that you have a slow starter circuit, because toroidal transformers draw a lot of current at start up and they can blow the fuse, or start with a very loud bang. Slow starter circuits are placed on the primary side and they limit the current for a short period (typically about 2 seconds), while the large capacitors are charged. This is necessary because the large capacitors short circuit the secondary side for a short time when they start to charge. The current rush cause the large bang and can also blow your mains circuit breaker, or fuse in the wall plug if you have one.
    Hi A camera
    I thought that might be a problem and bought one of these
    https://www.conrad.at/de/renkforce-6...20-622412.html
    I assume that should do the job, although I would like to build a power surge reducer into the case to be a bit more self contained, if anyone has a straight forward circuit diagram for such a device i would like to see it. Thanks in advance.
    Andrew
    I am using a 650vA toroidal transformer (transformer rating is a good guide to the amount of inrush current you get at startup) and I have a 10A MCB where the mains enters the cabinet. I used a C curve MCB in place of the more usual B curve, which is a bit more tolerant of short-term surges. Never had it blow - unless you have a much larger transformer you probably don't need inrush protection.
    Hi A camera
    Andrew
    Here is a simple circuit which will limit the current during about 1.5s which should be enough.
    http://electronics-diy.com/soft-star...wer-supply.php
    Even the one from Conrad which you linked will work, but it is limiting between 0.4-1s only. The circuit needed is pretty simple, but of course, if it is a commercial product then it has a price. Never the less, well worth investing in it. I have one built in my PSU, but an external one works just as well.
    Hi A_Camera
    Thank you for the link that looks like just what I need.
    Andrew
    Hi A_Camera
    Andrew
    You're welcome, but be careful if you plan to build one. As opposed to the 50VDC, the 230AC is very dangerous and should be handled accordingly and taken seriously.
    I'm always wary of mains power. Just out.of interest what is the amp rating of the rectifier in the circuit ? The round housing limits the options a bit. There seem to be different ones listed on the net. My electronics knowledge is self learnt. Am I right in thinking that the resistor capacitor network is the timer for the circuit. The article is a bit vague in the description of the circuit. I assume the rectifier is only to supply a dc to the relay so does not need to be high amps ? If I'm thinking wrong I'm happy to be corrected!!
    Andrew
    If you put in a DPCO relay you could use it to drop in a bleed resistor when the power is removed, after all this is what this thread started out as
  1. need help! choosing right kit
    By msacnc in forum Gantry/Router Machines & Building
    Last Post: 17-09-2014, 09:41 AM
  2. Resistor Question
    By GTJim in forum General Electronics
    Last Post: 07-04-2013, 10:01 AM
  3. Resistor Calculator
    Last Post: 17-04-2012, 05:22 AM
  4. ATX power supply - load resistor - do I need one ?
    By rckeith in forum General Electronics
    Last Post: 18-08-2010, 03:21 PM
  5. What type of resistor?
    By Smiler in forum General Electronics
    Last Post: 05-12-2008, 10:04 PM
